Trick Flow vs. AI Ported 226cc 243's?
Thanks Kevin I could not have explained that any better and you are 100% correct. On all the testing we have done running a roller rocker is the best option when getting into the higher lift cams. There are custom shops out there that will install powdered metal guides for you as an option but you will still void any warrenty by running the stock rockers.
Gregg
Gregg
