Another wont crank thread
Old May 23, 2012 | 06:04 PM
1nasty86's Avatar
Turd Gen Guy
Default Another wont crank thread
ok.. here is my problem.. i have a freshly rebuild ls2 with wiseco pistons, scat rods, stock crank... the engine will crank but will not start.. pulled the fuel rail to check to make sure the injectors were pulsing and they are.. also pulled a plug wire and tied it an inch from the coil and fire jumps to the wire... so i have fire and fuel... replaced the crank sensor..nothing, replaced the cam sensor... nothing, pulled another map off my truck... nothing... i have a main power wire and a main ground and they are both hooked up and another wire that needs power in ignition and in the crank position.. which it has both.. im stumped guys....
Old May 23, 2012 | 06:38 PM
FL Junkie's Avatar
this might be goin out on a limb, but do you have good compression? you have fire and fuel, only thing left is air.
Old May 23, 2012 | 06:43 PM
1nasty86's Avatar
Turd Gen Guy
dont see how i couldnt... -3.2cc wiseco pistons, new rings, new head gaskets, camshaft is a 239/246 .621/.615 112+3.. tuner said compression also but i dont see how.. i started the engine a few days ago and let it run for about 30-45 seconds and it idled down and sounded good..... then 2 days after the initial start up i tried to crank the engine again and it does what it does now
Old May 23, 2012 | 07:54 PM
Redbull87's Avatar
My car did this when I first did my swap and my ign wire was wrong and didnt have 12v during crank.But since you already had it runnin..sounds like its not a wiring issue.Do you get any codes while cranking,have you check all sensors are plugged in..like the maf/map,tb,iat,cts etc.Sometimes its the lil things that bite you.
Was anything changed after you first got it running?
Old May 23, 2012 | 09:59 PM
1nasty86's Avatar
Turd Gen Guy
no codes, all sensors are plugged in and the only thing i changed was some wiring at the battery but i have looked over that area 3-4 times and have found no loose random wires
Old May 24, 2012 | 05:40 AM
Old Geezer's Avatar
Fuel pump doing it's prime cycle at key on?
Fuel psi is?
Old May 24, 2012 | 06:19 AM
03Sssnake's Avatar
test the ignition relay, see if you are getting power there and try another relay.
Old May 24, 2012 | 06:39 AM
NHRA4MULA's Avatar
^^^^^^ What he said ^^^^ just switch it with the one next to it
Old May 24, 2012 | 04:19 PM
1nasty86's Avatar
Turd Gen Guy
Pump is priming and going up to 60psi... And I have a standalone harness since the ls2 is ok n a third gen... I also swapped the two outside cam wires prob. a year ago
Old May 24, 2012 | 04:33 PM
RandallBlackwell's Avatar
will it fire by manually priming it?
Old May 24, 2012 | 05:02 PM
1nasty86's Avatar
Turd Gen Guy
Your refering to what?.... Ya lost me
Old May 24, 2012 | 11:23 PM
chadtn's Avatar
The stock set up in my 98 and 02 Camaros had a ground wire that attached to the back of the driver's side head that would make the car not start if it wasn't hooked up or broken. You also might want to check and make sure the ECU has power and a good ground. Another problem I've run in to with motor swap cars are battery cables. Some times the factory stuff has little pig tails or connectors on the negative battery cable that won't be there on replacement cables.
Just a couple of ideas from problems I've had in the past...
Good luck!
Chad
Old May 25, 2012 | 08:42 AM
1nasty86's Avatar
Turd Gen Guy
went out today and open up the throttle body alittle with the set screw and its fired up 3 times so far today.. guess it was starving for air
Old May 25, 2012 | 11:37 AM
Redbull87's Avatar
Thats good to hear...its always the lil things that bite you.Hope its just an idle adjustment issue.
Old May 25, 2012 | 12:53 PM
1nasty86's Avatar
Turd Gen Guy
I hope so man.... But like I said it started 3 times since I opened the throttle.... Thats 3 more times than the past week
Old May 25, 2012 | 03:23 PM
Old Geezer's Avatar
Scan it and take a look at the IAC, tps...IAC should set for start, when key is turned.
Old May 25, 2012 | 03:42 PM
FL Junkie's Avatar
Old May 25, 2012 | 03:47 PM
1nasty86's Avatar
Turd Gen Guy
