can some one please help me
Old May 24, 2012 | 06:15 PM
67c10-6.0's Avatar
Default can some one please help me
I have a lq4 and I'm waiting to do a 12.1 compression can I do this on pump gas or do I.have to have 110.octane , if not what the highest compression , I can run on pump gas?
Old May 24, 2012 | 06:44 PM
crainholio's Avatar
Your cam selection has a great deal to do with this, read up on dynamic compression ratio and go from there.
Old May 25, 2012 | 06:53 AM
mark21742's Avatar
On my 408 I'm running 12.5:1 dcr, but 8.22:1 dcr with my cam (255/263 .624/.624 115lsa) on pump gas with no problems.....full 26 degrees timing and 0 knock spinning to 8,000
From everything I've searched and read 8.5:1 dcr, and about 200psi cylinder pressure is about max for pump gas
Old May 25, 2012 | 07:07 AM
helga203's Avatar
12.5 is pushing it on pump gas, your not going to get that much timing out of it. Less timing less hp. 8.5.1 cp is nothing. Once yuou start getting over 11.5 is where it gets tricky.
Old May 25, 2012 | 10:54 AM
mark21742's Avatar
Sorry, typo...damn auto correct...12.5 Scr, not dcr.....8.5:1 dynamic is max for pump gas.
When running a bigger cam you need to raise your static compression to keep your dynamic compression up.....the later your intske valve closes the lower your dcr will be.
At or over 8.5:1 sec is where you will hsve to start pulling timing and still might have troyble with knock on pump gas.
Old May 25, 2012 | 11:29 AM
PREDATOR-Z's Avatar
I've run 12:1 and 9 DCR with no issues on 94 octane.
Old May 25, 2012 | 11:40 AM
mark21742's Avatar
92-93 octane around here and I have always questioned having one pump nozzle for 87- 93....there has to be some cross contamination...I'd think
Old May 25, 2012 | 12:28 PM
badazz81z28's Avatar
Why?
Do you plan on driving this on the street? If I were you I would stick with 91 Octane fuel. Many pumps DO NOT have 92-93+ octane. Places like Utah barely have 90!
