TSP cam selection
I am looking at 3 different TSP cams. The 224R, 228R, and the Torquer V2.
I'm not 100% sure what my long term plans are for the car but current mods are ARH LT's, ARH ORY, Borla catback, SLP lid, BMR LCA's, Poly MMs. I plan on doing more suspension work for sure as well as add a torque converter, something like a 3400-3600 from a sponsor. Leaning towards FTI or Circle-D. I currently have a stock 10 bolt with 2.73 gears. I plan on eventually getting either a 9" or S60 with 3.50-3.73 gears and a built 4L60E from FLT or RPM. Not sure if I'll swap to an LS6 or FAST manifold. I may eventually do a head swap and/or a smaller nitrous kit, like a 75-125 shot.
The car is mostly a street car, maybe 50-100 miles in a typical week. I don't plan many trips to the track, maybe 5 trips max a year. I'd want it to be streetable which I know depends on the cam specs and the tune and I'd like to make peak power slightly lower in the RPM range so I don't have to rev the car that high. I plan on setting shift points to 6200rpm and limiter to 6500 (maybe 6300 and 6700 if its safe to do so).
Looking at the 3 cams I've mentioned, they all seem pretty similar to me so I wanted to get your input and see if you could differentiate them for me a little bit better.
Thanks
Your current rearend is not going to help you for now though.I have 3.23 gear and my 228r cam is sluggish below 2000rpm but winds up the mph.Tv2 would be better with a 3.73 gear imo auto..should make a very fun car with a stall aswell.
http://youtu.be/B0tEuYQRE_g
http://youtu.be/4k8Kr9nhaDA
