Low Power; Replace, rebuild, or sell?
Old May 30, 2012 | 02:38 PM
tripplewhiskeysip's Avatar
Default Low Power; Replace, rebuild, or sell?
Hey guys, The car is an 01 z06 w/ 90k miles.
I feel like its lacking power and should be quicker. Problem is that I don't know the history of the car or whats in it. It could be the tune, aftermarket parts, or just a worn out motor.
I did a COLD compression test and it confirmed bad numbers.
90-100 psi - first pump
120 psi - cranking
160 psi - with me squirting oil in the spark plug hole
I have the tools to pull out the engine and disassemble it. But I would like to see what other people would do in my position.
Most likely I was thinking to send the block to a machine shop and have them see if they can rework it. Then I would get new pistons with a rebuild kit and have my motor running good as new. I never dealt with a machine shop.
For guys that have dealt with machine shops can I give them all the big parts so they could check them before I assemble it. Since besides the block I was thinking of also checking the valves for leakage and getting a valve job if they are bad, and also the condition of the crank. (The crank seems fine, no knocking)
Do you guys know how much the machining would cost and also the rebuild kit? Because I've seen these motors go for $2500 - 3000 on the forums.
What do you guys think is the cheapest way to escape my problem.
Old May 30, 2012 | 05:58 PM
Gunslinger09's Avatar
Find a 6.0 truck block, and throw some forged pistons in it reusing the stock crank and rods and put your heads and cam back in it. Or do a 402-408 stroker the same way if money isn't an impediment.
Old May 30, 2012 | 06:52 PM
Transmission Perform's Avatar
>90k miles
>low cylinder compression
should have got an LT1 dude
Old May 30, 2012 | 07:06 PM
crainholio's Avatar
Originally Posted by Transmission Perform
>90k miles
Some more valuable wisdom from Transmission Perform here for your enjoyment:
Well first i have an old lt1 that broke down here's what happened i think
The cylinder heads became deformed because the air filter was so dirty they couldnt handle all the build up of air and oil coming through the air filter and the throttle body
so i tried replacing the air tube with a cold air intake and i think the extra power blew out the cylinder heads and they crashed through valley pan into the crank.
then the crank spun hard and threw the pistons up to hard to cause a misfire
well what im gonna try to see is i think the camshaft that needs to adjusted it's going through the intake valves right? so im gonna try to wiggle it around and fit it through the valves i guess this is what me and my dad came up with the mechanic told us this is the problem with the heads.
Personally, I'll take an LS1. They don't "blow out the cylinder heads and they crash through the valley pan into the crank" or need the valves adjusted by wiggling the camshaft and fit it through the valves"...
Old May 30, 2012 | 10:30 PM
Sounds like a good option. I'll keep it in mind to see if it will turn out to be cheaper then a replacement LS6 motor or rebuild.
Thanks
Old May 31, 2012 | 04:02 PM
Exidous's Avatar
>90k miles
Why does this person still have an account?
With numbers like that, your rings need replacing or the valves aren't sealing. You are getting about 8:1 static comp. Check your oil to see if there is a bit of fuel in it.
Old May 31, 2012 | 04:25 PM
Old Geezer's Avatar
"Some more valuable wisdom from Transmission Perform here for your enjoyment".
Yep!
Old May 31, 2012 | 09:30 PM
crainholio's Avatar
Entertainment value...
 Michael S. Palmer
