first fill up
Old May 31, 2012 | 07:44 AM
97badass's Avatar
Default first fill up
With oil, what weight should I use for break in on my lq4 h/c/i?
Old May 31, 2012 | 01:33 PM
PREDATOR-Z's Avatar
Brand new motor??
Old May 31, 2012 | 05:01 PM
00shortbox's Avatar
When I put the LS6 in my truck I put Mobil-1 5W30 in, and that's what I plan to run all the time.
Old May 31, 2012 | 05:05 PM
US_Army_Z28's Avatar
Castrol gtx full synthetic 5w30
Old May 31, 2012 | 05:42 PM
97badass's Avatar
Honed, new bearings, new rings, new cam, new heads, new timing set...
Old May 31, 2012 | 05:56 PM
I personally don't use full synthetic at initial start up. I use a petroleum base for start up, then go synthetic after you've drove it a little while. My engine builder says the synthetic stuff is "too slick" to allow parts to mate. Just another opinion.
Old May 31, 2012 | 06:01 PM
JUSTINSWS6's Avatar
I cant remember what i used to break in my stroker motor but i think strockers are different i would use gibbs break in oil. Dont use synthetic always break in on conventional.
Old May 31, 2012 | 07:40 PM
MonmouthCtyLS7's Avatar
Everyone is going to respond w/ what they use. I dont buy into the whole overpriced Gibbs break in oil.
Old May 31, 2012 | 07:48 PM
JUSTINSWS6's Avatar
I dont use gibbs. I use a 15w-40 conventional and a lucas break in additive. Jelps everything get together and helps break in all the valve train better. I only run the 15w-40 on a stroker. I would use 10w30 conventional with a lucas addittive . Much cheaper than gibbs.
Old May 31, 2012 | 07:49 PM
black00ssFL's Avatar
If it was built with stock bearing clearances, use regular 10-w30 oil. If not, then use whatever weight the builder recommends. Don't use synthetic....you need a little bit of friction to seat the rings and it'd be a waste since you're gonna be changing the oil right after first start up anyways.
Start it up and get it up to operating temps. Change oil after that if you wish....or move on to breaking in the rings and change oil after that. After it's up to operating temps, bring her close to redline for about 5-8 seconds (say 5,500) about 3 times. Then go ahead and change the oil.
If it's already tuned for the setup, go ahead and drive it and give it hell. Don't worry about driving easy and get it up to redline with a load as much as you can. Stay away from idling too much and steady state cruising for the first couple hundred miles. I'd change oil again after 150 miles or so.
If it's not tuned, try not to start it or run it until it gets a tuned or is getting tuned. Idling and babying the engine will cause the rings to break in "slow" and won't seat well, and before you know it the roughness of the hone job is gone and the rings will never seat completely.
Old May 31, 2012 | 07:55 PM
JUSTINSWS6's Avatar
Also Once the motor is started and broke in change it immediatly. Use same stuff go 500 miles change same stuff go 1500 change with same stuff go another 1500 then change to synthetic. Thats how we break in the motors we build. You first few thousand miles is critical with how the motor will be in the long run. You can still run it hard just change the oil like stated good luck. What motor do you have in the car again you told me a month ago but forgot.
Old May 31, 2012 | 08:29 PM
97badass's Avatar
Yeah I know to run the dino and not syn. I run Mobil in all my vehicles I just didn't know what viscosity to use
6.0 lq4 ls3 topend tsp 229/236 cam
Old Jun 1, 2012 | 07:22 AM
PREDATOR-Z's Avatar
The rings will seat in the first 20 min of operation. Use regular 10w40 for first 500 miles. Drive it at different loads (sometimes like you stole it). Change oil (still conventional) for another 1500 and then you can go synth.
Old Jun 1, 2012 | 07:35 AM
97badass's Avatar
The car needs a tune before it runs and will still be on the stand for awhile I just want to get oil in it and primed I'm gonna be putting it up and in hopefully this weekend.
