valve seals OEM
Old Jun 10, 2012 | 10:24 PM
LSXFEIN's Avatar
Exclamation valve seals OEM
do OEM brown exhaust valve seals come with the cups attatched? why are they so difficult to find anywhere!
Old Jun 10, 2012 | 10:27 PM
wildcamaro's Avatar
Believe it or not autozone sells the fel pro seals which are the same as oem I just installed some on a 2005 5.3 and they were identical to the factory ones. Only thing is they come as a set so you get both intake and exhaust or you can buy the exhaust ones individually which costs the same as the set
Old Jun 10, 2012 | 10:31 PM
LSXFEIN's Avatar
Exclamation Really!?
LOL really i have an autozone down the street from me.= well i should be fine with the orginal black/browns i guess, so since im using 799s i should just ask for valve seals for a 2005 5.3!
Old Jun 11, 2012 | 12:20 AM
LSXFEIN's Avatar
Wait 799's are off 07 silverados right?
Old Jun 11, 2012 | 09:01 AM
Damian's Avatar
LSX Mechanic
Ask for valve seals for an 02 Camaro Z28. The Felpro kit that matches that part # has the seal / seat made into one housing. Those are the ones I always use. Advance Auto parts stocks them.
Old Jun 11, 2012 | 04:38 PM
LSXFEIN's Avatar
Default thanks
will do man thanks
Old Jun 11, 2012 | 07:24 PM
wildcamaro's Avatar
I looked mine up for 2005 5.3 HO on a 4wd silverado which is what my all aluminum 5.3 came out of and it had the 799 heads...
Old Jun 11, 2012 | 07:39 PM
wildcamaro's Avatar
I work at the zone part time and the 02 z28 seals are the same part number
Old Jun 11, 2012 | 09:15 PM
LSXFEIN's Avatar
Default thanks
thanks for the info
Old Jun 11, 2012 | 09:16 PM
LSXFEIN's Avatar
Default Perfect
thanks man
