Check my math
Old Jun 13, 2012 | 09:30 PM
tilly's Avatar
Default Check my math
Ok, the heads I am putting on this motor have been milled 0.020 and putting in a cam. Usually on cams, the base circle is 0.010 to 0.020 smaller then stock. Can I get away with running stock length pushrods.
Old Jun 13, 2012 | 10:07 PM
badazz81z28's Avatar
This questions come up all the time...Why don't you just measure to ensure you have what you need?
Technically, simple math will work, but still not the best way to do it. Somone here will tell you yes, something goes wrong, next thing you know theres a post on here about valve train noise or valves hitting pistons...
Old Jun 14, 2012 | 07:20 AM
mark21742's Avatar
Drop your old pushrods in your new set up, then post how many turns from 0 lash to torque you get...minimum 3/4- 1 1/2 turns max is what you are shooting for...then go from there to get your needed pushrod length
Old Jun 14, 2012 | 09:37 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
At a minimum do like mark said in post#3. But you ALWAYS want and need to measure. It's a $20 tool that will pay for itself over and over!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
