head swap....any reason to clean carbon off pistons?
Im half way through my cylinder head swap....is there any real reason to go through the trouble of actually cleaning the carbon build up off the top of the pistons? If there is, Im all for it, but Im not one to waste time cleaning something for no reason.
Additionally, any tips for getting that last little bit of crap off the block surface? I used a plastic ice scraper, and then a credit card, but theres still a very light amount of residue from the original gasket...
Thanks
Thanks
Leave the carbon that extra few thousandths will bump your compression up....jkjk
Seriously though, to clean mine I put each piston at TDC and used a razor blade to get everything off. Took about 1 min per piston. Why wouldn't tu is the question? Your that far just do it...
lol.....yes, clean it all off, its not supposed to be there....
Here's what mine looked like after I had terribly bad valve seals. I was detonating like UNBELIEVABLE at just part throttle easy accelerating on hot days.
Like "A.R. Shale Targa" mentioned, it gets hot and causes the air-fuel mixture to ignite before TDC. I razor bladed them, then used SeaFoam to soak in and wiped the rest off.......
After I cleaned it all off......no detonation at all, no matter how hot the engine got.
Clean it ALL off.......it will just keep building up.
The best, safest and quickest way to clean your deck, heads and pistons is with a die grinder with a rubber finger pad. I've been using this method for years and never had a single issue with it. You can get them anywhere. Only a moron can remove actual block material and it makes unbelievably quick work of the job. Use some light grit sandpaper for any areas you can't get to with the pad.
