cam for stock converter
cam is:
219/226 .609/.607 115+4 comp LSL/LXL
ive got an 01 bolt on z28 with 4.10's and 243's (PAC 1518's) with .40 gasket
im hoping the 4.10's compensate for the probable loss of off idle power. The car is a street strip car but i dont want any lope so i need the cam to be "sleeper"
thanks
I had a 230/224 reverse split cam on the stock stall for a year. I hated driving the car and it wasn't really much faster than it would have been stock cam. But clearly your mind is made up so have at it.
With the stock TC a 212/218-114lsa would be a better choice.
It was the pulling at the brakes, having to shift to neutral at every light to keep from burning up brake pads in a matter of 2 oil changes, and the falling out of the power band between gears. With that being said, it was painfully slow from a stop too and wouldn't even spin the tires on good pavement.
The 4.10s might help that a little but then first gear will be so short it's almost useless. Not something I would personally want in my car, but everyone is different.
