EPS vs Pat G cams
Old Jun 23, 2012 | 09:50 AM
87DodgeD150's Avatar
Default EPS vs Pat G cams
I was wanting to have a cam specd up for my new build. I'm not sure if i want a eps cam or a pat g cam. I've heard good from both. Just wondering what your guys opinions would be between them.
Old Jun 23, 2012 | 09:59 AM
Tainted's Avatar
Pretty much one in the same. Pat works for eps
Old Jun 23, 2012 | 10:00 AM
milktasd's Avatar
Pat g uses eps lobes and Geoff at eps will use pat g to help spec cams.
Old Jun 23, 2012 | 11:34 AM
1nasty86's Avatar
Turd Gen Guy
Both are good choices... Id just have geoff spec it if your getting a eps cam
Old Jun 23, 2012 | 03:27 PM
99Bluz28's Avatar
Have Pat G spec it, and EPS(comp cams) grind it.
Old Jun 23, 2012 | 06:03 PM
Camaro99SS's Avatar
EPS designed their own proprietary lobe that's offered in x number of sizes and can be ground on any combination of those specs (comp cams grinds them). Pat G just specs cams for people as a side job (he owns a marketing firm) and he can use EPS lobes or anyone else's. Both are great sources.
It's worth noting that Geoff came up with some of Thunder Racing's most popular grinds years ago and now works for himself.
Jason
Old Jun 24, 2012 | 11:40 AM
Ellesone's Avatar
Either or... both have good reputations.. Comp has some nice lobes as well.. most people dont know where to look for them in the catelog
Old Jun 24, 2012 | 12:00 PM
NVR_SPDS's Avatar
I got a Pat G spec'd cam from EPS. Its a decent sized cam (227/230) and makes 411/391. I wasnt after peak numbers on this setup, but it makes 360 ft/lbs at 3k.
Old Jun 24, 2012 | 02:29 PM
SStressin's Avatar
i got a custom spec eps cam from geoff in my 383 no numbers yet but should be atleast 500! call them up you wont regret it
Old Jun 24, 2012 | 10:49 PM
garygnu's Avatar
get a cam from ether guy ,they are great people to deal with.if you can afford to take your car to them for a dyno tune consider that.
Old Feb 4, 2016 | 02:51 PM
The highlander's Avatar
Wink
What is PatGs contact?
Old Feb 4, 2016 | 04:37 PM
jmilz28's Avatar
http://www.guerragroup.com/#!camshaft-help/c1mq5
