head gasket help
Old Mar 31, 2004 | 10:18 PM
parish8's Avatar
single digit dreamer
Default head gasket help
lets try this in here
i just put a prety much stock 6.0 together, put in head studs, cam, springs, rod bolts and some cometic head gaskets. i have drivin it for about a month now and have been thru 4 bottles of nitrous. just recently i realized i have a tiny head gasket leak, i am presureizing the cooling system and loosing some coolant, like 1 cup every tank of gas. it is a tiny leak, i put 120psi to the cylinder and it took 20minutes before i had any increase in coolant sys presure(firmer hose).
what should i do?
just pull the one head and have it surfaced a min amount and reuse the cometic?
pull both heads and surface and use some felpro's($26/pair and local)
or do both heads but with some stock mls gaskets( ~$200for the set with bolts that i dont need, thats the only way i can get them)
i will be hiting this motor with a t76 next week
Old Mar 31, 2004 | 10:21 PM
BigTex's Avatar
You can get the MLS gaskets w/o the bolt set. Call Scoggin Dickey. They aren't on their site, but they have them. I have a set I can get the part number off of for you.
Old Mar 31, 2004 | 10:33 PM
parish8's Avatar
they may not have them available any more, i have tried a couple of places including cmotorsports and the local dealer who did a national search. the only thing out there is head gasket kits. i will give them a try though, thats what i would really like to do but not for $200.
Old Apr 1, 2004 | 03:52 PM
BigTex's Avatar
The ones I have sitting here are part number 12575392 and have one gasket per package.
