An odd P to V question
Old Jun 24, 2012 | 01:58 PM
rumblebox's Avatar
Default An odd P to V question
Im wondering if i should worry about clearance here.
LQ4 shortblock
Stock, untouched 823 heads(L99)
226/230 .600.600 114 cam
Im wondering if i will still have enough clearance with .027 gaskets because of the massive dish my pistons have. If my math is correct, that would put me at 10.31:1
Old Jun 24, 2012 | 02:03 PM
PREDATOR-Z's Avatar
.027 gasket is too thin IMO for street. Your quench will be too tight.
Old Jun 24, 2012 | 02:04 PM
rumblebox's Avatar
Even with a -7cc dish?
Old Jun 24, 2012 | 02:05 PM
PREDATOR-Z's Avatar
Dish has nothing to do with quench.
Old Jun 24, 2012 | 02:06 PM
badazz81z28's Avatar
You need to measure....Only way to know FOR SURE.
Old Jun 24, 2012 | 02:16 PM
PREDATOR-Z's Avatar
There is nothing to measure. .027 gasket is too thin. His quench would be around .020 or so and that is too tight for street. Quench is the distance between piston to head quench area.
look at the pistons. Even though they have a centric dish, the edges are what will be the danger.
Quench = compressed gasket thickness - piston (in/out) of hole position.
Old Jun 24, 2012 | 02:30 PM
rumblebox's Avatar
So could i get away with .030, or would .040 be optimal?
Old Jun 24, 2012 | 02:36 PM
He is concerned about piston to valve clearence. He didnt ask for your opinion on how thick of head gasket he should use.
He didnt even say its for a street car...
But I admit good on you for bringing that up.
Old Jun 24, 2012 | 03:05 PM
PREDATOR-Z's Avatar
Duh! Quench is a bigger issue here. That is the first thing to look at, rest is irrelevant.
You read carefully and you'll see his sig (mild DD setup).
To the OP, yes you could use .040 gasket, then you'll need to measure (LS3 head has big intake valve)
Old Jun 24, 2012 | 05:05 PM
rumblebox's Avatar
Ill grab some .040's and check with some clay. Im asking, because i know i have big *** valves.
I think .034 quench is plenty.
