Can i run a 6-7 sec 1/4 mile for $5000 with a 2002 Trans Am
OP i guess anything is possible if its going to be a 4 year project. you need to pick a different engine than a ls1, not going to cut it for that kind of HP, im sure the TA in that video does not have a ls1.
might be best just to delete the post and just keep saving your money and doing research.
Kind of surprised Crainholio hasn't chimed in yet
you know that monopoly money you win when your grandmother lands on boardwalk cant be used to buy parts right?
and a little fyi, its takes many thousands of dollars to go 7's in the 1/4. then you break it 2 passes later. and guess what? you spend many thousands to fix it.
Hell no you cant!!!!!!!!!! You gotta have alot in suspension ,,,Good car,,and transmission and rearend tooo and alot of Horsepower to go that fast. You can forget 6s==LOL===7.99 is your target and good luck. You can do it easy in the 1/8th mile but no way in the 1/4 mile.
Yes you can, 500 cu. in. stroker kit from Cunati, $2000 385 TFR heads, $2000 Tonka truck 10" rear end, $1000, just make sure you keep your steel hood so your parts that fly out don't hit anyone.
#38
