your thoughts on the 216/220 cam?
Old Apr 8, 2004 | 09:30 PM
apexman's Avatar
Originally Posted by M6HuggerSS
WOW those lobes and lift numbers are probly hell on the valvetrain ( springs ) !!!!!!!!
Met a guy at Moroso that ran this cam (216/220) with different rockers, 373's on an M6 and ran an 11.9 and 12.0 and 12.1's at 118 to 120. I think he said his lift equalled around 570 or so. That car was rippin'!
Old Apr 9, 2004 | 03:45 AM
PREDATOR-Z's Avatar
Check around and you'll find that this "small" cam can do 400 rwhp with the proper bolt-ons. I have one waiting to be installed. With 1.85 SLP rockers, you get to bump that lift a little and take full advantage of the agressiveness of the XE-R lobe. IMO a good set of LS6 heads (67cc PATRIOT stage II) and juice and that cam will plant me solid in the 10's.
Old Apr 9, 2004 | 06:22 AM
m1key99WS6's Avatar
I've got like 45K on my 918's with the 216/220 .579 .589 114 +4 cam, daily driven and I leave the line at 6700 RPM all the time @ the track. I wouldn't worry about the springs.
Old Apr 9, 2004 | 09:00 AM
soliari's Avatar
You leave the line at 6700??? I know this may be a little off topic, but wouldn't you neet a better 60' if you left the line at peak TQ vs. max RPM?? I've always wondered about that. Thanks.
Old Apr 9, 2004 | 09:17 AM
m1key99WS6's Avatar
I've left @ almost every RPM imaginable and the higher I leave the better the 60' is. I've tried every RPM and this works best in regards to 60 and ET. Try it, it feels good. Cam only = 12.1's @ 113 with a 3750 Raceweight and a 1.70 60' on a set of 5 year old 26x11.50x16 ET streets (with over 200) passes on em!
Old Apr 9, 2004 | 09:25 AM
soliari's Avatar
hmm ... i guess i need to do a longer burnout and try it. Last time i tried a launch over 5k, the ET Streets let go. My best 60' on ET Streets is a 1.87 ... most are in the 1.9x range
Old Apr 9, 2004 | 09:59 AM
m1key99WS6's Avatar
Do you have a line lock, they help out a lot in 2nd gear burnouts.
Old Apr 9, 2004 | 03:11 PM
soliari's Avatar
no line lock ... perhaps that'll be my next mod
Old Apr 9, 2004 | 03:25 PM
99-LS1-SS's Avatar
STF Veteran
Originally Posted by boomcase
I currently have the 216/220 cam with the lower lift of 525/532 on a 114 LSA, decided on this cam because I wanted it to be easier on the valve springs. Im pretty happy with the cam for its size , very well rounded but as some have said you will need a tune , I had misfire codes and idleing issues. My car ran a 12.18 , 12.19 at 111mph 1.70 60ft with 2800 stall, ls1 intake I was having some horsepower loss issues from something in my car at the time (Dynoed after track and HP was down to 327) and I still have the same problem with the new mods I did over the winter.
1. Graph 2800 stall ls1 intake 216/220 cam Pic
2. After track day with problems Dyno Pic
3. After new manley valvesprings , Hardened pushrods , LS6 intake , TCI 3800 stall , Trans pak , Pic
I do like the cam it has alittle lope to it and its a great performer, Ijust have to get my problems fixed . By the way my baseline before cam was 311/333 on the same dyno and my car ran 12.40s at 110 mph with 273 gears so my car has always dynoed low.
I need to get it to the track soon and see what it runs, I know that the TCI 3800 is taken away some of the RWHP so we will have to see what times it puts down before I start swearing again. LOL
If i were in your position , I would do the 224/224 . Great cam and proven performer, you have 410 in your car I dont think you will feel like you lose RWT.
I have a very similar setup as you did when you ran the 12.18. Did you have any weight reduction? What tires did you run?
Old Apr 9, 2004 | 03:28 PM
99-LS1-SS's Avatar
STF Veteran
Originally Posted by Mike's02Z28M6
Wow! That is sweet!
Any TR220 or TR224 guys getting anywhere near that gas mileage?
On the highway mine is decent. In town I can't keep my foot out of it long enough to get gas mileage worth a damn.
:example: Sig pic
Old Apr 9, 2004 | 05:57 PM
Got Me SOM's Avatar
try that asa cam too it might be worth checking into.
it will lope though.
Old Apr 21, 2004 | 12:32 PM
  #32
ulySSes's Avatar
How is the idleing on these cams?
ttt...
Old Apr 21, 2004 | 12:39 PM
  #33
DenzSS's Avatar
im looking for a good CA cam! im looking for a torque monster not a 6500 rpm cam!
ASA fits none of those qualifications.
Old May 6, 2004 | 08:40 AM
  #34
ulySSes's Avatar
ttt...
