installation time for new cam, heads, intakeifold and throttle body?
I've recently ordered a GM hot cam, ported GM LS6 heads, a Fast 92mm intake manifold and a fast 92mm throttle body for my '98 Z-28. Provided that everything fits as advertised, what is a good estimate of how long it would take for a good mechanic to install those parts?
Also, what, if any, additional parts are needed?
Thanks for you input.
Of course, this assumes your heads on the engine are still 98's.
Lastly, the 98 rockers were prone to failure, so while you have the heads off I would upgrade the rockers to a later year or upgrade with the Comp Cams trunion kit. I would also replace the lifters to the lastest version along with hardened push rods.
Other: throughly clean the radiator, inside and out (fins) while you have it apart as well as the AC condensor fins. You won't believe how much crud, sand, and pebbles that have accumlated in the fins of both over the years - particularly the bottom rows of each. I suspect by now they are completly plugged with debris.
A good shop will know that you can break the oil sender when removing the intake manifold if the intake isn't removed correctly, so if they charge you for a new one, don't pay for it. As a precaution you might want to make sure one is available locally rather than have to wait overnight to get a new one shipped in. I think the 98 style is unique compared to later years.
The 98 oil pump was prone to failure too, so get a later year oil pump (LS6) or aftermarket.
