Which cam is best for nitrous
Old Jul 9, 2012 | 12:27 AM
kalildude's Avatar
Default Which cam is best for nitrous
Ms3 or raptr or trex v.2 let me know your build how how well this cams did? I'm thinking 100 - 150 shot of nitrous on stock bottom end with rod bolts ls1 and stock top end with a th400 and 4:10s?
Old Jul 9, 2012 | 01:32 AM
TransAmcoupe98's Avatar
I know the MS3 has had plenty of use with the juice. One of the things you want is a good split between the intake and exhuast durations as you do not want to contaminate the intake charge. Get the exhaust out quickly.
Old Jul 9, 2012 | 07:45 AM
simplysix's Avatar
I heard the tick polluter lives nitrous. And you already have 4.10s so the would be a plus
Old Jul 9, 2012 | 09:13 AM
Whoa, you have a TH400 or are anticipating?
Old Jul 9, 2012 | 09:19 AM
kalildude's Avatar
I have one with an unlocked 4000 k stall
Old Jul 9, 2012 | 10:22 AM
Ok, with 4.10 thats a good foundation for sure. Id look at a custom grind honestly. Just a good split in i/e durations.
Old Jul 9, 2012 | 11:41 AM
kalildude's Avatar
Does any one have trex builds?
Old Jul 9, 2012 | 06:17 PM
LS1T56FTW's Avatar
I know plenty of people who have sprayed T-Rex builds, but as mentioned earlier, you want a little wider of an LSA for a serious nitrous build. I think the 'newest' T-Rex cam has 110LSA, you should be looking more for around 114LSA.
Old Jul 9, 2012 | 09:10 PM
mike c.'s Avatar
i have sprayed 8 different cams with different splits and didn't notice one cam being anything better or worse on n.o.s.
Old Jul 9, 2012 | 09:21 PM
^ This, the difference when you are talking 600-800rwhp levels for cm choices with nitrous are negligble for the most part. With the exception of reverse split cams...that wouldnt be the best idea to use one of those.
Old Jul 10, 2012 | 04:32 PM
kalildude's Avatar
Bump for stock nitrous builds?
Old Jul 10, 2012 | 04:47 PM
antirice69's Avatar
I have a 234/246 cam from EPS which is meant to work well with nitrous. Maybe try contacting them and seeing what they think about the same cam in your setup.
Old Jul 10, 2012 | 08:14 PM
kalildude's Avatar
Okay cause you would have to mod your ls1 cause that cam is to big
Old Jul 10, 2012 | 08:54 PM
COPO9560's Avatar
With a 150 shot and 4000 converter, depending on your rear tire size 4.10 might be too steep unless you are running 1/8 mile. Try to estimate your trap speed and do the math.
Hope you own stock in Exxon/Mobil cause this puppy will drink gas on the street with 4.10s and no OD.
Old Jul 10, 2012 | 10:21 PM
kalildude's Avatar
Haha and worst I was going to do e85 so a lot more gas will drain lol. I'm doing a 26 or 27" tire. It just a weekend/ track car
Old Jul 11, 2012 | 05:19 PM
kalildude's Avatar
Bump!!!
Old Jul 12, 2012 | 10:19 AM
kalildude's Avatar
Come on post your stock ls1 builds with dyno numbers please
Old Jul 12, 2012 | 12:52 PM
andys02r1's Avatar
Im cam only with a 150 shot. Car put down 553hp 660tq on a dynojet. My cam is a 228 232 614 600 111+3. Any of those cams your looking at will do fine on nitrous.
Old Jul 12, 2012 | 01:50 PM
kalildude's Avatar
Nice is your motor stock?
Old Jul 12, 2012 | 04:42 PM
antirice69's Avatar
I have a stock bottom end 346 with heads and bolt ons. Cam only the cam doesn't make power until 4500-5000rpms, but with heads it pulls like a freight train. No dyno numbers or legit track numbers unfortunately, but I'm in the process of hooking up my nitrous setup now.
