how does this grind sound
Old Jul 10, 2012 | 09:13 PM
groundZ-28ERO's Avatar
Default how does this grind sound
.600/.612, 114+4lsa. with ported 243's. should make decent power, and keep drivability halfway tolerable on a stock cube ls1, doing pistons as well.
Old Jul 10, 2012 | 09:22 PM
Shelby7's Avatar
It is a lot like Texas speed ms3 cam designed to run best on ported 243's.
intenseblue's Avatar
Duration? Way more important to know than lift.
Old Jul 10, 2012 | 09:31 PM
Old Jul 10, 2012 | 11:57 PM
TransAmcoupe98's Avatar
Check your PTV, especially if the heads are milled also and the type of head gasket being used.
Old Jul 11, 2012 | 12:16 AM
stryder's Avatar
looks like a comp cam grind that is a top end screamer
Old Jul 11, 2012 | 12:35 AM
bamaballa205's Avatar
You'll have great top-end, great driveability and not a lot of chop. Almost the same specs of my 1st cam with a 112LSA.
Old Jul 11, 2012 | 01:00 AM
PREDATOR-Z's Avatar
10.5* overlap not choppy enough???
Old Jul 12, 2012 | 03:46 PM
Not saying it won't be choppy. My choppy 110-112LSA could be diffrent from what you think choppy is. Yes a 114 have chop but like I said IMO it's not as bad.
Old Jul 12, 2012 | 06:22 PM
PREDATOR-Z's Avatar
Bama, LSA of 114 does not mean it is not VERY choppy. It is the overlap that dictates the chop intensity (not the LSA).
Overlap= ({Intake Duration +exhaust duration} /2) - 2xLSA in this case 10.5* overlap it is very choppy.
Old Jul 12, 2012 | 08:22 PM
moeZ28's Avatar
Think of this cam as basicly a G5X3 114...Thats about what it is and what it will sound like.
Old Jul 13, 2012 | 06:51 PM
top end is the goal
Old Jul 14, 2012 | 01:25 AM
jessanator's Avatar
I doubt he will have p-v issues with that lsa
Old Jul 14, 2012 | 01:28 AM
mark21742's Avatar
If your goal us top end you will like it....I daily drove my 04 GTO with a 238/242 .595/.595 112lsa infringe of a 4,000 stall.
My 115lsa has a pretty good chop to it....but it is a 255/271
Old Jul 14, 2012 | 03:55 PM
PREDATOR-Z's Avatar
