Main stud and main bolt question
Ive read both that the main studs and bolts can be reused and Ive read that they cannot be reused.
Which one Is It?
I did find all the bolts at a decent price but I still would like to know.
If I can reuse the studs and bolts then I can go ahead and torque the main caps down.
Thanx,
GMPhaSSt
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
On your originals, you'll see some sealer, which was put there to prevent oil from leaking from the block. Just put some sealer in the same spot, and torque.
