Wrong size valve retainers/locks?
Now, like i said, this was at about 11pm after a long day, so i was already frustrated, and i might have done something dumb like flip the retainers and seats. But i swear i took them out of the bags in the right order! Just wanted to know if anyone else ran into the same problem orrrr if i'm just dumb. Did search, but for such a specific problem, didn't find anything
On the retainer issue it sounds like they are just wrong. Are the locks radius groove like the valves should be? Or did someone put a square groove valve in the head? Pics would solve this.
Locks are radius, and i do believe the groove is square. Work took up more time than i thought today, wasn't able to check anything out
If it helps, the springs i had on the head before are K-Motion K750. http://www.jegs.com/i/K+Motion/571/K-750/10002/-1
I'm looking into the K-Motion springs at the moment to see what, if anything, i can dig up while i'm working. Edit: So far, two different IDs on retainers, 0.650, 0.735. Also these are what the K-Motion locks look like http://www.summitracing.com/parts/KMO-K-6110/?rtype=10
Edit: Called Lunati, spoke with David. He had not heard of this issue. Measured the valves, they are 11/32. So i just went ahead and ordered the right locks and retainers (PN's are 77048-16 and 75794-16 respectively), which ran me ~$80.
Also, since i had not made mention of it, i had no history on these heads. I bought an LS1 from a local, he gave me two sets of heads, said one was ported 5.7, other were ported 5.3 (339K casting, was told D'Agostino Racing heads). That's all i knew, so this has been quite a pain in the ***!
