Spark plug effects
Old Jul 20, 2012 | 04:02 AM
Ws6Dnero's Avatar
Default Spark plug effects
Would a cold plug like an ngk 3346 effect the idle and down low power of a motor and make it feel weak in lower rpms? My car feels lazy down low but pulls hard as hell in the higher rpm's. Im N/A for now an may be for a while. Should i put tr6 in to fix this? An is there any power loss between plugs? By the way the motor is an lq4, 243 heads, 64cc. With eps 226/230 cam on 114+4
Old Jul 20, 2012 | 05:01 AM
SippiSpeedhawk's Avatar
Has it been tuned?
Old Jul 20, 2012 | 07:46 AM
Ws6Dnero's Avatar
Yeah mail order from frost, think a dyno tune would fix what im feeling?
Old Jul 20, 2012 | 01:47 PM
99Bluz28's Avatar
You should be good with a stock heat range TR5, maybe a TR6 at most.
Old Jul 20, 2012 | 07:03 PM
Ws6Dnero's Avatar
I will swap em out and see if it changes anything
Old Jul 21, 2012 | 11:14 PM
pkozera's Avatar
I just did a cam swap replaced the tr6 plugs with the same they comr pre gapped at 40 but gm says 60 what are most of you running with just a cam,headers,and,catback.
Old Jul 28, 2012 | 03:29 PM
Ws6Dnero's Avatar
well i installed the tr6 plugs yesterday and my car idles better and runs better in the lower rpms now.
