heads?
Old Jul 25, 2012 | 12:22 PM
ramairz28's Avatar
Default heads?
iam looking to put 5.3 head on my ls1 and just wondering wat casting number heads i should go with
Old Jul 25, 2012 | 03:26 PM
96capricemgr's Avatar
243 or 799 are most sought after
Old Jul 25, 2012 | 03:32 PM
Sales1@Texas-speed's Avatar
What kind of build are you looking to do, and are you planning on having the 5.3 cylinder heads worked over before you install them?
Old Jul 25, 2012 | 04:07 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
The casting numbers you're looking for (For a 5.3 head) are 852 or 706.
I'd spend a good hour on Google searching on "Castech heads". These are the ones to stay away from.
Good bulletin here http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
Aaron can get you going in the right direction though if you so choose.
Old Jul 25, 2012 | 09:58 PM
ramairz28's Avatar
i wanted to bump the compression and i haerd putting 5.3 heads on can do that and i feel if i run the cam iam using it will make some nice power
Old Jul 25, 2012 | 10:14 PM
dr_whigham's Avatar
The Scammer Hammer
The point I was trying to make in the previous post was- and if I'm wrong, by all means correct me, be careful what you buy if it isn't from a vendor. Guys will sell you "low mileage perfect heads" when they are in fact cracked or prone to cracking Castechs. The bulletin I posted clearly shows the casting marks to STAY AWAY from.
Like I said, if you want a hastle-free experience, with people that know their craft, as well as can point you in the right direction, Texas Speed is great, as is any of our other sponsors. After all, if there's an issue, you want someone to stand behind it.
You very well may find out that a 243 or 799 casting milled to your specs may yield more power.
Old Jul 25, 2012 | 10:19 PM
ramairz28's Avatar
thanks for the im put i will contact taxas speed and see wat we can do as far as heads thanks agian
Old Jul 26, 2012 | 06:36 AM
Just to be clear dr_whigam and I just posted casting numbers from different years. The numbers he posted were earlier years and the numbers I posted are for just the last few years.
Old Jul 26, 2012 | 11:35 AM
dr_whigham's Avatar
The Scammer Hammer
That's actually true. Some of the 243's and 799's actually came from 5.3 trucks. Hell, mine came from a 2010 Silverado.
When I saw you wanted added compression though, I figured you meant the regular 5.3 heads.
Old Jul 28, 2012 | 03:45 PM
ramairz28's Avatar
well ur right i wanted to bump the compression up and heard 5.3 heads would do the trick i no the 243 r ls6 heads and 799 r truck heads then there r 706s and so on...i no the 706s arent the great heads if i were to put the 243's on with decking would it bup the compression?
