H/C Intake, makes low numbers?
Old Jul 26, 2012 | 06:50 PM
fuglyz28's Avatar
Default H/C Intake, makes low numbers?
Im looking at buying a car from a guy and the mods are as shown
Fast toys 85mm lid
Big Mouth 92mm TB
Fast 92 Intake
Custom Pat G 227/231 .613/.617 114+3
PRC 5.3l stg 2.5 heads 10.75:1 CR
LS2 Valley cover LS6 PCV conversion
Walbro 255lph in tank pump
SVO 42lb injectors
Pacesetter Lt's with TSP ORY into Hooker CB
25% UD Pulley
MSD 8.5mm wires
NGK TR6 plugs
the car Dyno’d 408/386 before exhaust change / LS2 valley cover, PCV conversion and 25% UD pulley were installed
tuned by Gforce Motorsports with 18" wheels and 410 gear, 6 speed.
Are those low numbers, decent mubers, good number what? If there low, what could be the problem or Cause???
Old Jul 26, 2012 | 07:54 PM
TransamGCS's Avatar
Fast toys 85mm lid
Big Mouth 92mm TB
Fast 92 Intake
SVO 42lb injectors
25% UD Pulley
MSD 8.5mm wires
NGK TR6 plugs
What kind of dyno? mustange dyno typicallyshow lower numbers than dyno jet but overall those are good numbers
Old Jul 26, 2012 | 10:27 PM
fuglyz28's Avatar
not a mustang dyno, n the car has a dana 60, would that suck up some power?
Old Jul 26, 2012 | 10:34 PM
Camaroking1996's Avatar
Those do seem low even through an S60. Was the tune spot on?
Old Jul 27, 2012 | 11:23 AM
stunna p's Avatar
Id think with your set up you'd be in the 480hp range.....
Old Jul 27, 2012 | 11:35 AM
Reckless's Avatar
Super Moderator
Does seem a little low if it was on a Dynojet
Old Jul 28, 2012 | 03:49 PM
fuglyz28's Avatar
now im told the car whitsmokes from decel from 6k-2500, he drives it 1-2 times a week to the corner n back, whats the most likely problem? ive heard tuning, to rich/lean on fuel, oil on top of pistons from not being opened up, seals, seats etc.
