Too much oil pressure?
Old Apr 3, 2004 | 02:12 AM
SSactionLs1's Avatar
Default Too much oil pressure?
When i did my cam install i went with a MTI ls6 pimp. The pressure started fine at start up, and ive never had any problems with the motor or oil comsumption. BUt SOMETIMES my pressure will read like 85~psi...most of the time its in the 60-70 range though.. Should i worry about anything or am i ok?
Old Apr 3, 2004 | 02:27 AM
Z28_HESS's Avatar
after my install it reads 19 I think I need a direct reading guage now. Don't know anyone else here.....
Old Apr 3, 2004 | 10:42 AM
evil02z's Avatar
Check or replace the oil pressure sending unit or check and make sure the IPC is f*cked up.
Old Apr 3, 2004 | 05:54 PM
Ipc?...
Old Apr 3, 2004 | 11:35 PM
soundengineer's Avatar
My pressure is up there until it warms up and the oil gets warm and thins out a little...then I ususally see about 45-50 avg with the high side at the track being up in the 80ish range......
Old Apr 4, 2004 | 01:05 AM
Ferocity02's Avatar
60-70 is fine. Mine is usually in that range as well.
Old Apr 4, 2004 | 09:10 AM
bigMAC's Avatar
Same here
