EL Torro vs. TSP 228r
I would say that cam is a mid-size cam and would be very drivable with a good tune. Nothing like a much bigger cam like some that are offered.
yes it is daily driveable, I drive my Vette all the time. You can PM rmtt for feedback as well
As for sending the 228r back, that is for you to decide, I know what I would choose.
I'm looking for a cam for my GTO.
Ls1
3880 with me in the car.
T56 (same gearing as the z06's)
OEM 3.46 rearend gear.
243 heads that will be worked over by AI to suite whatever camshaft I go with.
Fast 90/90
Pacesetter version 1 LT
UDP
Flowdisaster catbacks (probably will wither change this or at least add cut outs)
Car has already seen lots of nitrous and will continue to see it post H/C. Probably a max of a 150 after heads and cam.
I like the dyno graph above but was wondering if there would be any way to shift the whole tq curve the right about 500 rpm?
My car has already run 11.98@116 with a 75 shot, udp, flowdisaster catback, kn intake, slicks and skinnies, and a small amount of weight reduction. This same setup made 476 ftlbs at the wheel at 3200 rpm which slowly dropped to 400 tq at 6000 rpm. Hp peaked at 403.
My goal is for the H/C/I setup to trap and ET better NA than my current setup does on the spray, and then on the spray to trap somewhere in high 120s to low 130s if possible.
A big cam doesn't scare me in the slightest, but I don't want to give up the stock torque levels found below 3000 rpm, so that will limit things a bit.
I was looking at the torquer v2/3 and came across this cam...hp target if that means anything is 550 to 600 on the spray. Would the el torro be close to ideal?
Ls1
Fast 90/90
UDP
Im VEEEERY tempted to grab 4.10s for my GTO. Any track times/traps? And not that it really matters, but what kinda MPG's ya getting?
Ls1
Fast 90/90
UDP
Also El Toro is not a drag cam. It was designed as a strong street cam, more for Vettes than f-bodies (due to exhaust difference). It does well under certain parameters but not for what you are looking for IMO.
