EL Torro vs. TSP 228r
Old Aug 5, 2012 | 12:33 PM
  #41
TXZ28LS1's Avatar
Predator Z,
Your custom 230/228 cam that was spec for RMTT is the only custom grind that just made ridiculous power. All these other custom cams i see guys pimpin arent really that more impressive than a typical off the shelf cam.
But yes, RMTT setup is one ridiculous setup.
Old Aug 5, 2012 | 01:03 PM
  #42
Camaroking1996's Avatar
What was his full setup and how much power did he make?
Old Aug 5, 2012 | 02:50 PM
  #43
Bumpin' Yota's Avatar
Originally Posted by PREDATOR-Z
El Toro is not a nitrous cam. Why don't you contact Ed Curtis at Flowtech Induction. He has done many GTO setups and can cater to your needs.
Also El Toro is not a drag cam. It was designed as a strong street cam, more for Vettes than f-bodies (due to exhaust difference). It does well under certain parameters but not for what you are looking for IMO.
Thank you and will do!
Old Aug 5, 2012 | 05:17 PM
  #44
PREDATOR-Z's Avatar
Originally Posted by TXZ28LS1
Predator Z,
Chrs1313 went 10.66 cam only on 230/230, still one of the fastest small cams (small compared to all the other contenders)
Old Aug 5, 2012 | 06:07 PM
  #45
What were his specs on the cam? The same as your 230/230 cam?
Old Aug 6, 2012 | 03:17 AM
  #46
PREDATOR-Z's Avatar
Yes, it is exactly that cam
Old Aug 6, 2012 | 09:02 AM
  #47
85Iroc's Avatar
Just out of curiosity, why do you say it isn't a drag cam?
Old Aug 6, 2012 | 10:19 AM
  #48
PREDATOR-Z's Avatar
A full fledged drag cam would have better top end power. El Toro is more of an undercurve cam, kinda an all around cam. Perfect for street for which i designed it for. It works well in the 1/8th and tend to flatten a bit on the back 1/2. Still capable of 125mph on stock cubes cam only. A full fledged drag cam would be more in the 128mph range.
Old Aug 6, 2012 | 10:27 AM
  #49
TXZ28LS1's Avatar
Hell yeah.. Chrs1313 car is friggin fast. Pred, didnt he swap it out for a bigger cam though?
Old Aug 6, 2012 | 10:30 AM
  #50
PREDATOR-Z's Avatar
Yeah, when he felt ready to go faster and quicker. But it was bigger than the 230/230, he did heads as well and is into the 9s now. Chris is meticulous and does things right. His father has a nice ride as well.
Old Aug 6, 2012 | 01:37 PM
  #51
85Iroc's Avatar
Ok, that makes sense. I'm gonna be running 1/8th only. Do you think the cam will be holding me back much for now?
Old Aug 6, 2012 | 03:37 PM
  #52
PREDATOR-Z's Avatar
There is more than just cam to be quick in the 1/8th. Your stall is very important as well as is car weight and your ability to plant that power in a quick 60'
Old Aug 7, 2012 | 09:29 AM
  #53
85Iroc's Avatar
Well I understand that. I've been racing for a long time, just not a LS car. What I meant was, with all else being equal and well sorted out, I'm not gonna be leaving TOO much on the table with this cam right? I'm already thinking about a 4000-4400 stall instead of the 3600, even though the 3600 feels good on the street.
Old Aug 8, 2012 | 04:32 PM
  #54
Cooldude5231's Avatar
This is an El Torro cam only in a LQ9, A4 3600 stall
is that with factory untouched 317's??
i believe its 10:1:1 compression in the lq9's right?
Old Aug 8, 2012 | 11:09 PM
  #55
PREDATOR-Z's Avatar
Yes stock LQ9
