things needed with a ms3 cam??
Old Jul 30, 2012 | 01:00 PM
Cooldude5231's Avatar
then the plan is, lq4 bottom end, stock 241's with your polluter cam kit, ls6 intake, and full exhaust.
what kind of numbers should i be looking at through a m6??
Old Jul 30, 2012 | 04:07 PM
Fbodyjunkie06's Avatar
Our polluter has made consistently 410-415rwhp on stock heads through an M6 with a LS6 intake with 380-390ft. lbs of torque.
I would look for the same horsepower if not 5-10rwhp more and easily match that number in torque.
This thing is going to be a BLAST to drive on the street! You will actually have a little more PTV room with the 241 heads on the LQ4 than a LS1 would.
Old Jul 30, 2012 | 05:14 PM
so could i get away with 243's??
Old Jul 30, 2012 | 07:13 PM
With a 64cc chamber which the 243's have stock you would have 10.10 static compression while a stock LS1 has 10.32 static compression.
You could run 243's with that cam as it would have less compression and more clearance than a stock ls1 with stock heads.
This is based on a .052 gasket, piston .006 out of the hole, 64cc chambers, 4.00 bore and -6cc pistons. 4.030 bore would be 10.21 static compression which is still lower than a stock ls1.
Old Jul 30, 2012 | 07:28 PM
awesome!
thats what it is then.
just waiting on my 2 other motors to sell then ill be building this one.
thanks so much for your help guys
at how many miles on a truck motor would i have to worry about spinning a bearing??
Old Jul 30, 2012 | 09:13 PM
89ROC-Z's Avatar
SO with a cam as big as the polluter, would a guy need to upgrade the fuel pump and injectors?
Old Jul 30, 2012 | 09:25 PM
this x2 ^^^
