stripped bolts?!
Old Jul 28, 2012 | 04:14 PM
badamn's Avatar
Default stripped bolts?!
the two bolts at the rear of my oil pan are stripped.Can anyone suggest a quick fix.
Old Jul 28, 2012 | 05:30 PM
therabidweasel's Avatar
Doh! The long ones that go into the rear cover? I assume it is not the bolts that are stripped, but what they thread into?
Total redneck suggestion that i doubt will work is to cram a bunch of jb weld stick in the hole and use a little bottle jack to hold the bolt tight until it dries? Other than that it would take on hell of a helicoil or dropping the tranny.
Old Jul 28, 2012 | 07:15 PM
chevybayboy's Avatar
Bolts or threads if treads helicoil but I think tou have to pull the motor to drop oil pan
Old Aug 1, 2012 | 12:09 PM
badamn's Avatar
well at this point i was thinking of just taking that cover off and heli coiling it.I don't know whats behind that cover though or if i'll need a new gasket.
Old Aug 1, 2012 | 09:28 PM
johnLs1camaro's Avatar
lol i just did the same, luckly i have my motor out. you gotta becareful on the rear ones. you will want a rear cover gasket and rear main seal.
Old Aug 1, 2012 | 10:07 PM
lizeec's Avatar
You can get the rear cover with gasket, bolts and rear main seal already installed new from GM for around $65.00
Old Aug 2, 2012 | 06:53 PM
dirtbag's Avatar
I did the same thing. wondering if I can find a slightly longer bolt or if helicoil is the only option. The block threads are stripped, but if you stick a thin rod in there you can feel some threads still up there hence the need for a lightly longer bolt.
Old Aug 2, 2012 | 07:07 PM
GA95DCMSS's Avatar
I think the OP is talking about the 2 bolts that screw into the rear cover. It's going to leak a little from back there, but i just say go ahead and order a new rear cover and pull the trans when you get a chance.
