what is the most lift from a stock spring take??
just as the qustion states, im looking to upgrade the cam... what do u guys recommend on the lift on stock springs??
![Popcorn](https://ls1tech.com/forums/images/smilies/popcorn.gif)
Even if I was just stepping up to a GM hot cam I would upgrade the valve springs to comp 918's or PAC1218's
Please don't try to push stock springs....they are already 11 years old an weaker than they were from the factory
yeah man, for all the research ive done, the LS1 springs are maxed out with the LS1 cam, pretty much any cam you choose, you have to upgrade your springs. If your not lookin for anything major, the GM Hotcam is a kit for like 480 bucks, comes with cam and ls6 springs, decent cam, especially for your stock setup. Can even use a mail order tune on that cam comfortably
I am running a Lingenfelter GT1 cam (.563,.563, .219,.229 on a 113) with yellow springs which Lingenfelter actually recommends. Yellow springs can be picked up pretty cheap also.
The mistake you guys are doing is trying to decide which spring to use based on lift capabilities. You should choose springs based on open closed pressures required by cam.
The above LPE cam has soft lobes and LS6 yellow springs pressures fall within its range.
Do you know a source to read that can detail some of these different facets of cam specs and dynamics in at least a somewhat comprehensive way?
With my research on the forums, all I've managed to really understand is how to read a cam spec, and how duration and LSA come together to tell you the actual overlap of the particular cam (and, although a semi-trivial aspect of it, how it will idle and what kind of emissions footprint to expect in a simple context). I just don't feel, even through digging on the forums, there is enough information to really genuinely learn much about it.
Maybe I'm asking too much, but I don't want to have to work as an engine builder or study engineering to at least have a decent grasp on what kind of cam I should use for a given application, and beyond that what kind of cam I can install that would be friendly for a daily driver in the valvetrain longevity department, not just driver comfort.
Hell, is it just that a typical vendor doesn't post the REAL information you need in favor of only lift, duration and LSA? I have no clue, and I would love some insight.
Thanks, and good day to you.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It's kinda funny actually, I once had a book written by David Vizard that I lent to a friend because at the time I couldn't understand it much at all. Looks like I need to get that book back.....
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Hell I'd probably put springs in even for a stock cam, can't hurt anything to have a better piece of mind when it blips 6k rpm plus time to time.
Even while in the car, springs aren't too bad to change.. I'm using a 35 $ basic compressor tool and a $20 compression tester kit with needle removed to air up cylinders to keep valve from falling, takes about 2 hours in the car taking your time.
