Lets play "what valve spring is this?"
Old Jul 31, 2012 | 07:15 PM
LSCha0s's Avatar
Default Lets play "what valve spring is this?"
I broke a spring and need to replace it. I might go with dual springs but.... Can anyone tell me what this is.
Its in a cam only (MS3) car with 241 heads.
Old Jul 31, 2012 | 08:08 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You'll need to pull out a few springs and measure them. Then go shopping for one that matches.
Then replace the full set.
Old Jul 31, 2012 | 08:12 PM
LSCha0s's Avatar
I'm thinking of going with a whole new set but I'm still curious about the spring itself. Would measurements help?
Old Jul 31, 2012 | 08:29 PM
usnfenix's Avatar
without a number or logo stamp, just identifying by looking at the spring alone ill say good luck. just buy a new set.
Old Jul 31, 2012 | 08:44 PM
LSCha0s's Avatar
10-4 .. its the best think to do
Old Jul 31, 2012 | 09:42 PM
Paul Bell's Avatar
I would think the springs should somewhat match the cam. The OP stated it's got a cam, certainly the springs were installed to match it.
If he pulled out a few springs, an engine shop can measure them and he'll know what springs will match the cam.
Old Aug 1, 2012 | 08:22 AM
Brian Tooley Racing's Avatar
Might be a 918 spring? I guess it could be anyone's beehive spring though. The single beehive springs do tend to fail more than dual springs.
Old Aug 2, 2012 | 12:04 PM
LSCha0s's Avatar
Its not a beehive. It measures 1.26 outside diameter top and bottom. I talked to someone who knows about springs and he thinks maybe someone took a the middle spring out of a dual spring setup so they could run the stock seal. I think he may be right. Anyway Im looking for a kit now. Lunati any good?
Old Aug 2, 2012 | 12:38 PM
Originally Posted by LSCha0s
Its not a beehive. It measures 1.26 outside diameter top and bottom. I talked to someone who know about spring and he thinks maybe someone took a the middle spring out of a dual spring setup so they could run the stock seal. I think he may be right. Anyway Im looking for a kit now. Lunati any good?
Please consider my steel retainer spring kit, it sells for $219 shipped. Some more info here: http://www.briantooleyracing.com/660...s-engines.html
Old Oct 3, 2012 | 12:13 PM
LSCha0s's Avatar
I forgot to give you guys an update. I replaced the springs with duals and all is well. Thanks for your help and advice.
