Crank or heads first
Old Aug 1, 2012 | 09:30 PM
smahlum_21's Avatar
Default Crank or heads first
I am gonna put my heads on and on the ls1howto site it says to put the crank on first. Is that true or needed? Also someone told me I should have engine at TDC when I put on the crank, is that true?
Old Aug 1, 2012 | 09:36 PM
IllusionalTA's Avatar
HuH? You have a bare block?
Old Aug 1, 2012 | 09:45 PM
wildcamaro's Avatar
You mean the crank pulley? I put heads on first...Then timing cover then crank pulley...
Old Aug 1, 2012 | 10:50 PM
smahlum_21's Avatar
Ok didn't think it would matter either way
Old Aug 1, 2012 | 10:57 PM
wildcamaro's Avatar
You wanna have the the heads on first so you can turn the motor over with the front cover off to see where tdc for #1 cylinder to tighten the rockers in sequence...
Old Aug 1, 2012 | 10:58 PM
96s-10ss's Avatar
Doesnt matter either way, the crank pulley is not keyed and has no timing marks so you can do either first.
