bbk vs ls6 intake
On the heat soak yea the air is going into the engine so fast its not going to heat up from sitting in the intake. The deal with the heat is that the alum. intake is going to hold heat longer then the composite. If your running rounds or racing on a road course then it will matter. So cooling the car down between races is going to be harder.
Go to the track and cool the motor down and, ice down the intake and compare the #'s to those when hot lapping the car.
