HPE megadeath cam NEED HELP!!
LS heads are LS heads as long as it's cathedral versus cathedral? Valve events are also valve events they don't change due to what car they are being used in.
but it sure is cool to post the youtube vid of your car idleing how badass is sounds.
AI ported 243/799s and a mid- high 230s cam with the correct boltons will make some serious power, and not just peak. It will make power down low.
My wife's car is running a mid sized cam (EPS 227/230 .614/.609 113 +1) with stock 799s and makes 330ft/lbs @ 2500rpm.
so when i pick up my stage 2 ported 243s (heads will be bare) and upgrade the rockers/lifters/springs/valves to match the cams requirement then i should have no problem with this
Go back and check now. If you're running stock rockers use the Platinum .660" spring kit. If you're currently running after market rockers use the Max Pressure .650" kit.
1.8's will raise the lift, the duration, and make the ramp rate of the lobes too aggressive for the springs you will be using.
Use 1.7 ratio rockers.
Here is the link to our Valve springs on our web page.
http://www.tickperformance.com/brian...ll-ls-engines/
