HPE megadeath cam NEED HELP!!
Old Aug 12, 2012 | 06:30 PM
Z28Dave's Avatar
Default HPE megadeath cam NEED HELP!!
i just got my hands on a HPE megadeath cam 244/242 612/610 112LSA what do i need to safely run this on my car? i have some stock 317s on it and i'm looking at some 1.8 roller rockers and comp cam beehive .625 valve springs, will they fit? what else do i need????
Old Aug 12, 2012 | 07:30 PM
BKsNHRA's Avatar
That's a healthy can for beehives. I would definately run dual springs with that. I also would not run 1.8 rocker. Stay 1.7.
Old Aug 12, 2012 | 07:41 PM
KCS's Avatar
KCS
Moderator
Is this on a LS1?
Old Aug 12, 2012 | 08:25 PM
Z28Dave's Avatar
as far as retainers or lifters what do i get? will the stock ones work?
and yes it will be going on a LS1
Old Aug 12, 2012 | 08:27 PM
01_SuperSlow's Avatar
I don't think you can run 1.8 rockers on that either.
Old Aug 12, 2012 | 09:48 PM
KCS's Avatar
KCS
Moderator
The cam is already too big, the springs are too weak, the 1.8 rockers are going to make it even worse, and the 317 heads are going to drop the compression. I think you seriously need to rethink your combination.
Old Aug 12, 2012 | 11:15 PM
Z28Dave's Avatar
Well I only had the 317s on because I was going to go turbo until I saw the glory of all motor setups. but right now I'm looking at a set of 241 or 243s but my budget is a little tight and payday is 2 weeks away so I can afford the 241s but I want to set it up right
Old Aug 13, 2012 | 09:04 AM
MM98's Avatar
I agree with KCS 100%!!! Stock cubes, 317's & way over-cammed= turd.. That combo would have the all motor glory of a 4.3 v6 with 2.73 gears in a 1 ton truck.
Old Aug 13, 2012 | 12:31 PM
Exidous's Avatar
Some ported 243's from AI or even 241's with [B]1.7[B] rockers and some springs good to .650 (PRC duals would fit the bill) Either way that's a really aggressive cam and it will feel like a dog down low with 317's. 5.3L heads would be better to get the compression up.
The 1.8 rocker would give you a lift of .648". Even with a 1.7 rocker you will need to check PTV clearances.
Old Aug 13, 2012 | 12:32 PM
Rise of the Phoenix's Avatar
You may want to look at LS1GTO.com (GTO forum). Lots of guys over there run that monster. You would be able to see what valvetrain setup they use to compliment that cam and get an idea on dyno numbers, track times, powerband, etc.
Old Aug 13, 2012 | 12:35 PM
01'SSLSX's Avatar
i couldnt have said it better...lol
OP u should contact a professional for advice before you waste your $
Old Aug 13, 2012 | 01:01 PM
MR2liter's Avatar
If I recall correctly the Megadeath cam was cut to be an all out stock longblock cam. If you are going to run that cam keep your 1.7 rockers, don't use 317 heads, and get some 3.73s and a tune.
Old Aug 13, 2012 | 02:24 PM
Z28Dave's Avatar
Well I'm postin from my phone do I can't quote 01'SSLSX this is why I haven't started te build so I consulting the owners users and semi professional (you guys) we all have to start somewhere to learn the does and don'ts and everyone is helping me out very generously. I will be putting different heads on the car most likey ported 243s but yes thank you all for your input much appreciated
Old Aug 13, 2012 | 05:47 PM
JakeFusion's Avatar
Super Hulk Smash
What's your goal with the car? That's a big cam that'll love the strip but little else. And I'd recommend 4.10s with that if an M6 or a 4000+ stall in an A4.
Old Aug 13, 2012 | 08:14 PM
Z28Dave's Avatar
I'm aiming for a street able 450RWHP and yes it's a M6 with 3.73s. I found a set of ported 243s that'll I'll be picking up
Old Aug 13, 2012 | 09:08 PM
Sales@Tick's Avatar
Going to take a pretty big cam with an LS6 intake, and a stock set of 243's even ported 243's to make that and still be as street-able as a smaller cam.
All depends on the port work really, if it's a set of AI heads or TEA heads then yea I can see it doing that with a street-able cam.
I would also consider 4.10's with the 6 speed unless you have to keep the 3.73's.
1.8's will make the lift even higher, the duration higher and ramp ratio higher all things that I bet those springs can't control.
We have a great valve spring package if you're interested. Zero failure rate with the springs I'd like to see you use.
Old Aug 13, 2012 | 10:28 PM
Z28Dave's Avatar
I am Interested I don't want to cut any corners so I'm taking my time with this
Old Aug 14, 2012 | 12:21 AM
wildcamaro's Avatar
Just do a lot of research and the number you are looking for will be fairly easy to accomplish with the RIGHT parts...think before you buy but the ported 243s are a good start and you don't always need a donkey dick cam to make good power...good luck
Old Aug 14, 2012 | 12:23 AM
JakeFusion's Avatar
Super Hulk Smash
I second the TEA Stage 2 LS6 heads. You can get them with turned down LS3s for a lighter valve and the Brian Tooley Racing springs (which is what TEA used to use before moving to PAC). Mill them down .030" and run a thinner gasket and flycut away.
Old Aug 14, 2012 | 07:20 AM
Sales@Tick's Avatar
Those are the springs we use
TEA/AI ftw. Oh yea, and a Tick custom cam
