Timing chain recommendation
Old Aug 13, 2012 | 08:45 PM
kossuth's Avatar
Default Timing chain recommendation
Anybody have any timing chains or timing sets they would recommend for a mild build. Don't want to do any messing with the pump and want AOK clearance on the front cover without grinding etc. Obviously stock is an option, wondering what else is out there that is a quality choice. Gonna be a 220ish cam.
Old Aug 13, 2012 | 08:48 PM
autogeek23's Avatar
ls2 chain is what i put on mine.
Old Aug 13, 2012 | 08:59 PM
derrickman05's Avatar
Me too!
Old Aug 13, 2012 | 09:04 PM
Sales@Tick's Avatar
We sell a LS2 chain.
Old Aug 14, 2012 | 01:02 PM
pairof69s's Avatar
does everyone just use the ls2 chain without a dampener..? I need a new chain, but some of these LS2 chain's i've seen I wouldn't feel comfortable running without one. I see Trickflow has a new piece that allows you to adapt the LS2 dampener to the LS1LS6 blocks...looks like a good idea
http://www.totalengineairflow.com/pr...apter-bracket/
Old Aug 14, 2012 | 01:18 PM
soundengineer's Avatar
actually, the Manley double chain doesnt require you to do any clearancing anywhere...
I run one, and have had one on other vehicles as well...never had to clearance anything..ever...
http://www.thunderracing.com/shop-by...g-Set_763.html
Part# 131-73333
another option is the MAST gear drive
http://www.mastmotorsports.com/2010/news-view.php?id=47
have to be running a Dry Sump to use this product
Old Aug 14, 2012 | 01:19 PM
TransAmcoupe98's Avatar
What about the C5R?
Old Aug 14, 2012 | 03:15 PM
1nasty86's Avatar
Turd Gen Guy
ls2 chain for the win..... i bought a slp double roller on here for 65 shipped way back when.....
Old Aug 14, 2012 | 03:30 PM
JakeFusion's Avatar
Super Hulk Smash
Get the Katech/IWIS C5-R chain. It's expensive, but you'll never need to worry about a timing chain again. Plus, it's a single row, so no problems with clearance.
Old Aug 14, 2012 | 03:41 PM
Darkman's Avatar
Agree.
Old Aug 14, 2012 | 08:28 PM
thepitstop2010's Avatar
Katech c5r is the most reliable in my opinion
Old Aug 14, 2012 | 09:13 PM
Camaroking1996's Avatar
What timing chain gears should be ran with the C5R chain?
Old Aug 15, 2012 | 04:59 AM
mjs1012's Avatar
Pretty sure you can use stock gears w/ the c5r chain.
Old Aug 15, 2012 | 06:41 AM
Darkman's Avatar
Affirmative.
Old Aug 15, 2012 | 07:24 AM
vettenuts's Avatar
Not sure how many miles are on your motor, but you may want to swap the sprockets as well. They do wear a pattern that over time will make chain wrap more of a risk. Since its apart and they are cheap, I would replace them. The Cloyes Hex-adjust is adjustable and uses the LS2 chain. They used to make the set with the IRL chain, which was the best chain ever made for the LS motor, but SDPC bought all of these from Cloyes a year or so ago and am not sure if they have any left in stock. The IRL chain was a blueprinted hand assembled chain originally designed for the Olds Indy motor. The Katech chains is a close second and the LS2 a close third. The chain used for the Katech chain is also used on several high end cars, including the BMW M5 which is a high revving motor.
As previously mentioned, there is more to a chain than just the chain. A timing chain damper will help with chain wrap and your choice of harmonic damper (pulley) will make or break the timing chain. Stay away from ASP. A 10% ATI would be my choice here.
Old Aug 15, 2012 | 10:23 AM
Sales@Tick's Avatar
We also sell this!
Old Aug 15, 2012 | 10:48 AM
badazz81z28's Avatar
SLP pump/chain combo fits under stock cover.
