lq4 tolerances
Old Aug 15, 2012 | 11:45 AM
Quickfrc's Avatar
Default lq4 tolerances
Did a quick search and came up with nothing. Im looking for the longblock clearances and specs for the crank thrust, main cap bearing, rod bearing, camshaft thrust.....etc.. Anyone have this? My machine shop didnt have it. Im about to assembke this motor and want everything checked.
Old Aug 15, 2012 | 06:03 PM
Z28Drifter348's Avatar
Just a hunch but I'm pretty sure they are the same as the ls1 which should be easier to find info on. The lq9 I'm assuming would be different because of the heavier duty rods but it might be the same as well.
Old Aug 15, 2012 | 11:16 PM
mcdonald77's Avatar
ask and you shall receive
http://www.pleasurecraft.com/manuals/L510016.pdf
Old Aug 16, 2012 | 02:16 AM
bww3588's Avatar
Clearances from an iron block to an aluminum block will be different because of expansion rates. From the factory, probably not by much, but when building a good higher power engine, it should be set differently.
Old Aug 16, 2012 | 06:26 AM
Did not know this but it makes perfect sense. Thanks for the correction.
Old Aug 17, 2012 | 04:22 PM
Quickfrc's Avatar
Thank u sir....
