Opinions on a budget 370 lq9 build...
I wouldnt mind using those as long as i could keep a decent compression and flycut for a bigger cam.
Im assuming these are the ones..
http://www.summitracing.com/parts/SLP-H1129CT75MM/
so u have ran with no valve reliefs .595 lift cam and ls3 heads I'm doin the same tru-flats and ls3 heads I'm just worried bout ptv. What duration was that .595 lift cam. I was gonna go asa cam and try to clone ls3 525hp motor...
