Compression for my 408 with this cam...too low?
Currently the set up below gives me 10.3:1 SCR 7.75 DCR:
408 Cid
PRC CNC Heads 227cc w/72cc chambers
240/244 cam .609/.612 114LSA on 109ICL
3600 stall
A4
3.71 gears
LT dual exhausts
I don't want to mill my heads and risk the intake ports and bolts not matching after that...
My other simple option would be to get a smaller cam...
i am still trying to figure out what is a good dynamic comp, without getting any pre ignition/detonation ,, i have heard 8.5 dynamic is max on 93 pump.
If you go with a 236/240 111+4 that should get you dcr up to a little over 8 and only bring the overlap up from 14* to 16* and you power band will be around 300rpm lower.
...that's in line with what I'm thinking....smaller cam, advance it to close intake sooner and raise DCR to around 8.2....my SCR will still be low at 10.3 but pump gas friendly for sure....wonder how much power I'm really leaving on the table with a 10.3 scr vs 11+ compression and this setup..???
Next size bigger is the 235/243 113+4....2200-7200....
and then 99Bluz28's 236/240 111+4 recommendation...
Am I splitting hairs at this point and/or does anyone see a clear cut advantage with any of the 3 mentioned above? All are smaller and therefor probably better for my particular set-up...question is which one?
I went with the smallest cam (231/239) knowing that in my other engine (418/LS3) I have a 236/242 and also still the 240/244 on the shelf.
THanks to all who posted, appreciate your insights...
Drive safe
Stroker2112
