Intake Selection Help Please??
Old Aug 20, 2012 | 05:28 PM
02BlkZ28's Avatar
Default Intake Selection Help Please??
Ok guys little brief explanation. Im trying to decide on wheather or not to use the victor junior in take with a elbow or the FAST 102 mm setup for my LS1 393 stroker 11:5:1 compression 215cc trick flow heads and 238 242 duration cam. Any help and suggestion on clearence on the victor setup would be really apreciated.
Old Aug 20, 2012 | 05:46 PM
badazz81z28's Avatar
I would go with the FAST 102. Proven performance and fit....
Old Aug 20, 2012 | 09:02 PM
02BlkZ28's Avatar
I like the fast system I had it on my first build with a stock 346 with heads and cam and and put out 456 at the wheels. I decided to build a strocker motor and wanted to know if I shold step up to the 102mm setup or if I should go Victor Junior with a eldow. Bascially I want some opions on the Victor setup and clearence issues pros and cons basically.
