need torque monster cam that is spray friendly
Do you need a kit or just the cam?
If you'd like you can e-mail me in the link in my signature or PM me. I'll be at the shop tomorrow, but we are dynoing a local 275 drag radial racers car and working on mine so I don't know how much I'll be around the phone.
a cam and it timing events determine how much pressure is in the cylinder.you can have high compression and a big duration cam with the right valve events will allow you to run pump gas ,with the proper timing and curve.a smaller cam with the same high compression engine will have a higher dynamic compression ratio ,because the vales are on their seats for more crank degrees retaining pressure .static compression is volume,dynamic compression is pressure.
