rocker beaRINGS
Old Aug 22, 2012 | 09:05 AM
ls1 fever's Avatar
Default rocker beaRINGS
I have a noise coming from the passenger side upper end on my Ls1. Think it might be a bearing in one of the rockers going. can these be replaced ?
audio link here
https://www.youtube.com/watch?v=kZTl...1&feature=plcp
Old Aug 22, 2012 | 09:10 AM
dodson55's Avatar
yes the bearings can be replaced pull the valve cover to make sure its the problem it sounds valve train related could also be a lifter bad as well
Old Aug 22, 2012 | 11:14 AM
ls1 fever's Avatar
how will I know if the rocker bearings are bad?
Old Aug 23, 2012 | 08:37 AM
ls1 fever's Avatar
where can I buy the bearings to replace them?
Old Aug 24, 2012 | 09:40 AM
ls1 fever's Avatar
how do I post a picture from my computer ??
Old Aug 24, 2012 | 09:46 AM
Undertow74's Avatar
drain your oil, if you have needle bearings in there, there ya go. pull the valve covers and look at the trunions on the rockers, you will be able to tell if the bearings went
Old Aug 24, 2012 | 10:54 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Unfortunately this is a common issue, but most guys will upgrade to the Comp Cams Trunion Upgrade Kit to fix this issue and to prevent it as well.
Here is a link to our site:
http://www.texas-speed.com/p-361-com...s-engines.aspx
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Aug 25, 2012 | 02:32 AM
ls1 fever's Avatar
I do not have little needles in my oil but I do have fine metal shavings that were collected on the magnetic drain plug
Old Aug 25, 2012 | 06:44 AM
89 formula350's Avatar
whats the story on the car?
just driving one day and you heard a lifter tap?
installed a cam and noticed this new noise right away or even sometime after?
just trying to get an idea why you think its the rocker arm. although its very possible incorrect push rods and collapsed lifters sound like this too
Old Aug 25, 2012 | 10:28 AM
ls1 fever's Avatar
car was cammed when I bought it last year.
basically I missed 3rd gear bounced it off the limiter and heard the noise slightly after.
Old Aug 25, 2012 | 12:44 PM
brucer's Avatar
i'll guess, bent pushrod
Old Aug 25, 2012 | 07:57 PM
see if you can locate the area with a stethoscope or long screwdriver to your ear so you can at least narrow down the suspect area and remove the valve cover. push rods would be a great idea! still could be a rocker arm but dont limit yourself to those two items. take a good flashlight and fully inspect the valve spring too.
Old Aug 25, 2012 | 11:12 PM
ls1 fever's Avatar
ok thanks guys
if its a bent rod should I replace them all?
also, I don't know the particulars on this car so how do I know what rods to buy?
Old Aug 27, 2012 | 03:51 PM
Are you using an aftermarket camshaft/aftermarket valvespring combination?
__________________
Old Aug 27, 2012 | 11:17 PM
ls1 fever's Avatar
the car was already setup when I bought it last June.
camshaft/springs yes after market not sure what but not stock.
Old Aug 28, 2012 | 09:05 AM
Can you tell if you have aftermarket pushrods as well?
__________________
Old Aug 31, 2012 | 09:14 AM
ls1 fever's Avatar
I would assume the pushrods are aftermarket if the cam is too right?
Old Aug 31, 2012 | 09:29 AM
I would assume so as well, but with the many different things that we seen and heard about, I wouldn't totally write off that a factory pushrod could still be in there.
__________________
Old Aug 31, 2012 | 09:32 AM
Also, have you pulled the rockers to verify that they are all in good working order, just to make sure none of them are seized up or anything unusual?
__________________
