Ls6 heads question
Old Aug 23, 2012 | 11:24 AM
ICEY?'s Avatar
Default Ls6 heads question
Ok. So I just got some ls6 heads that I'm putting on my 1999 ls1.
1. Will ls6 heads bump compression without milling?
2. Will I need to do anything to my pistons?
3. I heard there is a gasket I can use to bump compression? If not what gasket should I run.
Iv read a lot. But any more info would be a great help. Thanks!
Old Aug 23, 2012 | 12:55 PM
badazz81z28's Avatar
[QUOTE=ICEY?;16650997]Ok. So I just got some ls6 heads that I'm putting on my 1999 ls1.
Over stock LS1 heads? Yes
No, as long as you don't over due cam
Yes, if you run a thinner head gasket. Thickness is up to you, but thiner is not better.
Old Aug 23, 2012 | 07:11 PM
garygnu's Avatar
you want about a .035 quench when choosing a head gasket.
Old Aug 24, 2012 | 07:36 AM
ICEY?'s Avatar
So would you guys recommend milling them alittle? Or just throw them on as is.
I want to run a 125 shot also.
Old Aug 24, 2012 | 08:52 AM
goober35's Avatar
Not trying to slam you, but with your knowledge of the ls1 i would not mill the heads. Slap them on with a set of new springs and run them.
Old Aug 24, 2012 | 09:22 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
OP, what camshaft are you/will you be running?
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Aug 24, 2012 | 09:32 AM
ICEY?'s Avatar
I wouldn't be milling them myself of course.
But the cam size is 232/236 .595/.602 114lsa
Old Aug 24, 2012 | 12:31 PM
batboy's Avatar
1. Yes, 243 heads will bump up CR
2. I'm running a similar cam and did nothing to my pistons
3. Cometic .041 gaskets are thinnner than the stock GM MLS gaskets. But, honestly the GM gaskets seal better. You could probably get away with a .010" mill if you wanted. That's what I did to mine just to clean 'em up.
Old Aug 24, 2012 | 08:15 PM
Bnawty00SS's Avatar
i am running the ls6 stage 2.5 from texas speed milled .025, with stock pistons and stock gm head gaskets. had plenty of piston to valve clearance even with a pretty large cam 231/239 .617 .623 car runs great, sounds great even on a base tune! it hits the dyno tom morn for final tuning. just make sure you account for pre- load when measuring for your push rods!
Old Aug 24, 2012 | 09:34 PM
garygnu's Avatar
check the valve seats for any leaks,do a valve job if you find a leak..006 is about equal to 1 cc.valve to piston clearance mostly depends on valve timing events.if you have the cam card list all the valve info ,intake opening etc.
Old Aug 27, 2012 | 03:55 PM
When we mill our cylinder heads, we usually perform a valvejob as well, thus recessing the valve and gaining back PTV clearance.
__________________
