232/238 cam only Ls1. What Size push rods?
I'm guessing 7.4 with comp beehive springs will do the trick? What pushrods would be best. I see different pushrods like magnum comp and hi tech comp push rods.. is one better then the other or are they almost the same thing?
http://www.ebay.com/itm/COMP-Cams-62...12e3fb&vxp=mtr
Sorry here are more specs on the cam if it helps.
http://www.lunatipower.com/Product.aspx?id=2025&gid=288
OP you need to measure for p-rod length.
Well the majority of regular builds use 5/16 .080 wall prods. These are usually available in increment of .025.
Now there are thicker than .080 walls available and also Mantons as more custom.
The less deflection done by the p-rods the better valvetrain stability and performance is given.
LS1Tech Premium Sponsor
We stock several different lengths in the 5/16 hardened pushrods for $109.99.
In case you are interested, here is a link to our page. Keep in mind there is a drop down menu at the bottom of the page to select whatever different length you need.
http://www.texas-speed.com/p-278-tex...-pushrods.aspx
We also offer the length checker for $19.99.
http://www.texas-speed.com/p-275-com...h-checker.aspx
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
