2000 6.0 questions
Old Aug 23, 2012 | 11:54 PM
akasquirt01's Avatar
Default 2000 6.0 questions
i have a 2000 6.0 and have been reading about the long crank and short crack my plans for this eng is to rebuild and install it in a 94 s10 with a 4l60e trans if im right may eng has the long crank and this will cause problems with the trans/converter. so my question is when i am rebuilding my eng can i use a crank out of a 01+ newer eng but still run my stock rods with new pistons
please help new to the ls family thanks
Old Aug 24, 2012 | 04:43 AM
LS1MCSS's Avatar
You can swap the crank without problems. Can you post a pic of the rear of the motor?
Old Aug 24, 2012 | 06:56 AM
Chrome_Rust's Avatar
You can also run any pre-LS trans behind that engine already. Just use the 6.0 flex plate and elongate the holes for the bolts as needed. Your 4l60e will already bolt up and work. It's exactly what I'm doing, everything has been test fit, and so your home work is done there.
Old Aug 24, 2012 | 09:50 PM
i will post off pics tomorrow when i get in to the shop and start the tare down i just got the 6.0 this week it came with a 4l80e would that be a better trans to run or should i stay with the 4l60 that came with the s10 im tring to get 300hp to the ground for a daily drive i know the block is a 99 or 00 because it has iron heads which i have a set of 806 heads and a ls6 intake with stock injectors the plans is to freshin up the bottom end and change the cam and topend
Old Aug 26, 2012 | 06:57 AM
LS1MCSS's Avatar
If it has iron heads, it old enough that it will have the longer crank. I don't think the 60E will bolt up. The convertor will stick out about .400 too far. Use the 80E that came with the motor if you can make it fit into the S10. It's a much tougher tranny.
