Cam install degree?
Old Aug 22, 2012 | 04:40 AM
DisasterpeaceWS6's Avatar
Question Cam install degree?
Installing my new cam and want I need to know is do I need to "degree" the cam or is it fine just installing with the timing lined up. I am a little bit confused with this part.
Old Aug 22, 2012 | 11:33 PM
Ok got it. Thanks.
Old Aug 22, 2012 | 11:56 PM
XpEdItIoUs's Avatar
You need to install it at the cam card specs. You will need a degree wheel, a pointer and a dial indicator. some simple math and of course a degree-able cam sprocket setup.
Old Aug 23, 2012 | 12:23 AM
chevybayboy's Avatar
Is degreeing a must or can you line crank dot to cam gear dot?
Old Aug 23, 2012 | 12:28 AM
I can line crank dot to cam dot. That is what I was unsure about is can i get away with just doing that or if I needed to do the whole degreeing process.
Old Aug 23, 2012 | 12:51 AM
XpEdItIoUs's Avatar
You can install it dot to dot but wont get optimum efficiency from the cam. I highly recommend you degree the camshaft to the manufactures spec. If you don't have the tools or know how pay for someone to do it for you. if you search online you can find articles and/or videos on how to degree a camshaft.
Old Aug 23, 2012 | 01:28 AM
OK I was unsure as well every time I installed came I just lined dot to dot I'm going to look up degree ring if not to hard or expensive I'll do that if not then dot to dot.. but can't it also be adjusted wen you get a tune?
Old Aug 23, 2012 | 02:29 AM
Im not sure at all about the adjustment after tune. This is my first car that I have mod'd so I am pretty new at all of this.
Old Aug 23, 2012 | 03:03 PM
PREDATOR-Z's Avatar
LOL a tune doesn't adjust those parameters.
Old Aug 23, 2012 | 04:09 PM
Lol I wasn't to sure its a lot more to learn about theses engines then I thought I knew I'm looking up degreeing cams and I'm not quite getting it I think I'll just line dot to dot sorry for the tread jack op
Old Aug 23, 2012 | 04:14 PM
Old Aug 23, 2012 | 08:21 PM
XpEdItIoUs's Avatar
No, your basically advancing or retarding the camshaft depending on the cam card specs. it's all mechanical. You have to do it before you get the pcm tuned for optimum efficiency of the cam swap.
Old Aug 23, 2012 | 08:57 PM
Burken01's Avatar
It should be correct dot to dot, but people and machines make mistakes and they get ground slightly diff than what was proposed..
I was always a dot to dot guy because I figured if it was made by pro's then it's all perfect.
But I guess it comes down to how much of a perfectionist do you want to be? I.e. Checking pushrod length, cam degree, etc..
Old Aug 23, 2012 | 09:47 PM
sepsis's Avatar
Well, checking push rod length isn't a "perfectionist" thing. That needs to be done for proper valve train geometry.
Old Aug 23, 2012 | 09:59 PM
Burken01's Avatar
I can can count the threads when they ask "what push rod with 243/317heads" on stock ls1.....
So I think it's quite the same, there is alot of shops I won't name and tuners who specifically gave me dot to dot advice
Old Aug 23, 2012 | 10:05 PM
XpEdItIoUs's Avatar
It has nothing to do with machine mistakes, it has to do with how the camshaft was ground by the company. It is the deg of the centerline of the intake lobe ATDC. Some large camshafts have to be properly deg or else you can have PTV contact.
Old Aug 23, 2012 | 10:18 PM
XpEdItIoUs's Avatar
I agree the lifter pre-load will determine noisy valve train, shitty engine idle or a quite smooth engine.
Old Aug 24, 2012 | 01:30 AM
sepsis's Avatar
Yea, with a stock cam. The dude is installing a new, I assume custom cam.
Old Aug 24, 2012 | 03:11 PM
Im installing a tfs 228/230 cam with 215 tfs heads
Old Aug 24, 2012 | 07:40 PM
willyfastz's Avatar
Restricted User
You could get by with dot to dot, but when you get it on the dyno and something doesn't seem right. A good tuners probably going to start asking install questions. And did you degree the cam is probably going to be one of the first. If you degree it and the power doesn't seem right you'll know it isn't because the cam isn't installed correctly.
Measuring the pushrods would be the next thing that most don't do.
