Need all the tips/tricks I can get!!!!
Old Aug 28, 2012 | 10:01 AM
jrob56's Avatar
I would start with chris1313 ram air non ac version, UD pulley, and suspension.
Old Aug 28, 2012 | 10:20 AM
spicebird98's Avatar
3.90 gears, ram air duct (check SSRA), and possibly getting the converter restalled a bit higher. What are you shifting at and what does your launch technique consist of? should be able to improve on that 1.7x by a good bit
Old Aug 28, 2012 | 10:31 AM
BIGDATOWN's Avatar
I put the car in drive and stall it to 2800 and let it eat! I think my lack of gear, heavy weight car/driver, and torque managment are keeping the car from running the number I am looking for!
Old Aug 28, 2012 | 11:26 AM
mkvamso's Avatar
You foot brake it to 2800?
Try just flashing the convertor and see if it cuts your 60'
Old Aug 28, 2012 | 11:33 AM
BIGDATOWN's Avatar
I tried and it doesnt work. I can footbrake the car to 3200 on the street with street tires tho lol Leaving at 2800 is the best it can leave
Old Aug 28, 2012 | 12:09 PM
1_MEANZ28's Avatar
Free mods will help u
http://www.gmhightechperformance.com...modifications/
There's more pages online .look em up
Old Aug 28, 2012 | 12:15 PM
BIGDATOWN's Avatar
Only ones I can use will be the cutting under the air box and the descreening of the maf. But these type of mods are what I am looking for!!
Old Aug 28, 2012 | 03:02 PM
GA95DCMSS's Avatar
You can footbrake it to 3200 on the street?! That must be one hell of a loose converter! Try launching from a lower RPM. I was launching at ~22-2400 and dropping it down to 1800 allowed the converter to hit the tires harder initially. Just my .02
Old Aug 28, 2012 | 03:15 PM
BIGDATOWN's Avatar
Ive tried every launch rpm and 2800 is the sweet spot!
Old Aug 28, 2012 | 11:21 PM
slammedc5's Avatar
Carbon fiber driveshaft?
Shed some pounds from the car. And reduce power train loss to the rear wheels ( unsprung weight)
Attached Thumbnails Need all the tips/tricks I can get!!!!-driveshaft_installed.jpg
Old Aug 29, 2012 | 07:55 AM
jrob56's Avatar
I wouldnt descreen the MAF, the free ram air has its place, but since your trying to drop your time .3 Id go with a true ram air, like the Chris 1313
Old Aug 29, 2012 | 08:17 AM
  #32
BIGDATOWN's Avatar
Where might a guy buy one of these?
Old Aug 29, 2012 | 08:26 AM
  #33
Sprayed1998's Avatar
Tune, UD Pulley, Ram Air, Electric Water Pump, Cutout, Gears, Suspension, More Weight Reduction. Do you have to run the stock intake manifold?
Old Aug 29, 2012 | 09:15 AM
  #34
batboy's Avatar
The guy I quoted is on the money, although the electric water pump is not a good bang for the buck, expensive for only a little gain. You have a LS1 intake manifold, right? If so, would get a LS6 intake manifold (externally nobody will notice the difference and it can be worth 8-10 hp). Port the throttle body and do the TB coolant bypass mod. UD pulley will free up 5-8 hp. Probably a lot more weight reduction that can be done as has been said. The biggest gain would be a good tune, you are leaving a lot on the table with a stock tune. Good luck.
Old Aug 29, 2012 | 11:06 AM
  #35
BIGDATOWN's Avatar
My car is a 01 so it already has the LS6 intake. And I already have a Bo white TB and coolant bypass done. I have contimplated a electric water pump. But that can wait till I need one. I think my plan right now will be more weight reduction, UD pulley, ram air and a aggressive tune up! We shall see what happens. Gears will come when I install the 9"
Old Aug 29, 2012 | 11:31 AM
  #36
The stuff you have planned should get the job done.
Old Aug 29, 2012 | 12:08 PM
  #37
slammedc5's Avatar
http://www.pstds.com/carbonfiber.htm
Old Aug 29, 2012 | 07:52 PM
  #38
nastychevelle's Avatar
1.8 rockers
UDP
Ram air
Adjustable Shocks and LCA's
Torque arm
Rear bumper support (bumper shouldn't become a parachute at your speeds.)
front kirky's
remove the sound deadening from under your stock carpet.
Start there
Old Aug 30, 2012 | 05:11 AM
  #39
mark21742's Avatar
Originally Posted by nastychevelle
1.8 rockers
UDP
Ram air
Torque arm
front kirky's
Start there
I normally beer people away from 1.8 rockers, but this time I agree, I think they would really help...just be sure to upgrade the valve springs at the same time.
Old Aug 30, 2012 | 09:18 AM
  #40
89ROC-Z's Avatar
Take as much weight out, and get a big stall like 4800+?
