blow- by
Old Aug 29, 2012 | 11:29 AM
JustAFooL's Avatar
Default blow- by
I'm in the process of tearing my car down for my head swap. Heads are milled to 59cc so I'm looking at a serious bump in compression. Is this what cause blow-by? Just curious as I'm about to order everything and was just curious if I need a catch can too..
Old Aug 29, 2012 | 01:42 PM
mark21742's Avatar
I'd recomend a catch can on any build....I bought one off eBay for around $35....liked it and bought two more for the other cars
Old Aug 29, 2012 | 03:02 PM
JustAFooL's Avatar
What exactly us It and what causes it
Old Aug 29, 2012 | 05:00 PM
outkast6991's Avatar
Blowby is compression gasses making it out the chamber
Old Aug 29, 2012 | 05:13 PM
ZeeOSix's Avatar
Specifically past the piston rings and into the crankcase. Higher compression will cause more blow-by because there is more cylinder pressure that the rings need to hold back.
Old Aug 29, 2012 | 05:49 PM
JustAFooL's Avatar
Does a catch can stop it from smoking or what??
Old Aug 29, 2012 | 06:15 PM
mark21742's Avatar
The catch can "catches" the oil, but let's the air/pressure back through the intake...the lower the pressure in the crankcase the better the rings seal and the less blow by you have
Old Aug 29, 2012 | 08:42 PM
JustAFooL's Avatar
So a pcv valve will help everything??
Old Aug 29, 2012 | 09:13 PM
It won't hurt but it won't fix worn rings either. A catch can will yield better results
Old Aug 29, 2012 | 09:43 PM
chevybayboy's Avatar
Where can you buy this catch can ?? You say on eBay what do I search for ?
Old Aug 29, 2012 | 09:51 PM
JustAFooL's Avatar
Ok, my motor is at 100k, never been on juice or boost, only on cam for the past 5k. Never really been ran hard either in comparison to others. What do you guys think about my rings?? The reason I'm so concerned is I hate seeing smoke and unless I can help it, I about refuse to see it.
Old Aug 29, 2012 | 09:52 PM
a good can would be about $200. google sakou michi (sp?)
Old Aug 30, 2012 | 04:10 AM
sabersaw30's Avatar
Becareful with the eBay catch cans som will let oil go right thru. Spend the money and get a can with the screen in it to stop the oil.
Old Aug 30, 2012 | 03:23 PM
ZeeOSix's Avatar
I have the Elite Engineering catch can ... works pretty good.
http://www.eliteengineeringusa.com/Catch_Can/
http://forums.corvetteforum.com/c5-t...s-on-sale.html
Installation Instructions
http://www.eliteengineeringusa.com/i...tructions.html
