Head Milling question?
Old Sep 8, 2012 | 01:19 PM
KrazyKamaro's Avatar
Default Head Milling question?
How much would you have to mill a set of 853 heads to get a 62cc chamber?
Also what would the compression be at this point? I'm thinking somewhere in the 10.8:1 to 11:1 range. Or am I way off? (everything else being stock ie. stock head gasket thickness, bore, stroke, and pistons)
And if this was done would I have to worry about PTV? (Cam is currently a MTI SII Cam 224 220 .581 .581 116)
Also how big a cam could I go with if I used this head combination and still maintain proper PTV without fly cutting the pistons?
Old Sep 8, 2012 | 01:51 PM
dgcustomz's Avatar
853's are 66.67cc
66.67
-62.00
=4.67ccx.007=0.03269
Mill about 0.033"
Old Sep 8, 2012 | 02:02 PM
dgcustomz's Avatar
3.898 bore
3.622 stroke
8 cylinder
62cc
0.050 headgasket
=10.87 compression
Head gasket is actually a stock 0.054 gasket but after it's compressed it's closer to a 0.050 .
Old Sep 9, 2012 | 09:46 AM
Anyone on the PTV issue or the max size cam I could run with these heads? (853 heads milled about 0.033" with stock MLS gasket)
