torquer v3 cam
You will have to measure for proper pushrod length during your build. Its easy to do.
I too also highly recommend the 228 cam. They are great for about 400whp on stock heads. 224 cam's are very small and have limited house power capabilities compared to the 228, I have seen 375whp with them
I recommend dual springs for any cam. I will never buy comp springs again after having a set that was part of a "bad batch" when they came out a while ago
And like mentioned before..timing set and oil pump would be wise to do now than later.Get a decent exhaust,cold air intake and you will have over 350whp easy with a tune.if your auto..a stall is always a must have upgrade, even stock.Good luck on your build.
You can use that cam without touching the heads or bottom end. Pick it up used, and get some take off ls6/ls3 springs, hardened pushrods (new to avoid getting one that is bent), Ls2 chain and better oil pump.
With that, you should easily come in cheaper than the entire kit from Tsp and you should easily see 375 at the wheels.
Now, here's the other side. Since your car is stock, I would also invest in a set of lt's and a better exhaust. You can also pick up a set of 98 injectors to keep your fuel on the safe side, but your stock injectors should suffice. And the most important part, is make sure you save enough cash for a good tune.
