need help identifying 6.0 block, pic inside
Old Sep 20, 2012 | 05:07 PM
baggins's Avatar
Default need help identifying 6.0 block, pic inside
So from what I gather this is a 9/01 block can anyone verify that?
Old Sep 21, 2012 | 02:42 AM
baggins's Avatar
Anybody... that casting number is front passenger side of the block
Old Sep 21, 2012 | 03:38 AM
badazz81z28's Avatar
May I ask why? Usually these questions spark From numbers matching restros
It's 6.0 what more do you need to know ?
Old Sep 21, 2012 | 04:07 AM
bww3588's Avatar
You need to know the month and year on iron 6.0's to get the correct cam bearings.
In my case, having an over the counter block, 2nd hand, I had to have the machine shop measure then call around to find the correct cam bearings to match the bores.
Old Sep 22, 2012 | 07:17 PM
baggins's Avatar
I need to know what head studs to order...
Old Sep 22, 2012 | 08:36 PM
bww3588's Avatar
Date doesn't really matter in that case, you either have all short bolts or long and short. Just measure the bolt holes, if you have some deeper than others, you need pre 04, if they are all the same depth, you need the 04+
Old Sep 22, 2012 | 08:59 PM
baggins's Avatar
Well bring that its getting rebuilt I guess I need to know what cam bearings as well
Old Sep 22, 2012 | 10:40 PM
bww3588's Avatar
Yep, unless you can get some dead on od's of the bearings, it's tough.
I ended up buying all 3 sets and measuring to get the right ones.
